Changed spark plugs now weird grinding noise
Hey guys sorry to bother you with this. I just changed my spark plugs on an 08 Is250 two days ago and it went without any problems. After I did that I started noticing a sort of grinding noise or some weird water pressure noise. Sort of like when your shower head is clogged and struggling to get water out. It's hard to explain.
The noise only occurs randomly when I accelerate after being stopped at a light or somewhere for a little over 45 seconds. The sound usually only lasts 2 seconds at most but it's so random that I can't predict when it's going to happen. I'm not sure if it's related to the spark plug change and me not hooking everything up properly but I can swear I triple checked everything. My acceleration and idle is normal so I'm just lost as to what it is.
It almost sounds like my brakes are sticking on my driver side and I'm just being paranoid because of the spark plug change.
Any ideas would be great and helpful. Again sorry if it's a simple fix.
Thanks for the reply
Hopefully it's nothing serious. I triple checked everything while I was putting everything together so it can't be anything to do with the spark plug change. It's starting to do it as I reverse out of the garage as well. I'll have to investigate some more this weekend.
I was just hoping someone here would have some sort of idea of what it could be.
Hi I have same problem, did you figure out what it was?
Kimblestix
RX - 1st Gen (1999-2003)
09-11-13 03:27 PM
satz
02-14-11 01:50 PM
banking
SC- 1st Gen (1992-2000)
21
12-06-01 10:57 AM
