Finally Buying Wheels...
Auto Detailing Master
Well my tires need to be replaced on my stockies, so I'm finally just going to buy new wheels & tires rather than putting fresh tires on my OEM wheels... I think I have settled on the Ground Force GF07 Wheels. I really liked them when they came out and I think they look great on this IS.
These wheels can be ordered with custom offsets, so I need a little help choosing the best specs.
I want to have a nice fitment that does not look sunken in, but nothing that will create issues for a DD. I am OK with rolling my fenders, but that is all I am willing to do to make these wheels fit (ie no pulling or excessive camber).
Here is how my car currently sits (lowered ~1.75")...
I am OK with running a very minor stretch, but I need enough sidewall to take a slight beating as the roads around here are not great due to our crappy winter we just had. I am considering the following tire sizes, but would really appreciate recommendations for tire size & offset.
19x8.5 front w/ 235/35 tires (already have these tires, bought them used for a steal)... offset?
19x10.5 rear w/ 265/30 tires? 275/30?... offset?
I am hoping to purchase wheels in the next few days, so any advice is greatly appreciated!
Thanks in advance!
Thanks in advance!
I really like this type of fitment... flush enough to look aggressive, and still enough tire.
Recommendations for such a fitment with 8.5 front and 10.5 rear?
Recommendations for such a fitment with 8.5 front and 10.5 rear?[/QUOTE]
With the tires you have, you should go +35 all around. Btw the car in the link you posted is mine and you messaged me on instagram lol
With 8.5+30, You will rub with a 235/35/19 if you're too low
Id go with a +35 offset or run a 225/35 tire.
I rub the bumper support tab (its the metal piece that the plastic bumper bracket mounts to) on big dips and that's the exact setup I'm running. (8.5+30 w/ 235/35)
Do you think I will rub in the rear with a 10.5+35 and a 275/30? Will I have to roll front & rear fenders, too? (just wanting to plan ahead of time so I can get it taken care of before I order the wheels)
^I'd be interested to know the exact specs, I know the LC818's come with a 10 +38, but I remember seeing that the car in the photo also had spacers though I don't recall how much they were spaced out. Thanks!
Thanks guys, I appreciate the help!!
-Zach
^I already have 235/35 tires for the front so those are what I will be running for now, so I suppose a +35 would be the best choice. Do you have your fenders rolled with your 8.5 +30 setup? I know people modify the bumper bracket - I haven't ever seen a technical "How-To" on that... is it easy/needed?
-Zach
And yeah, I'm running no bumper tab / fenders rolled. You shouldn't have a problem with a +35 offset though! If you do need to modify the tab, its fairly easy.
8.5 +30 235/35 (possible fender liner rubbing)
10.5 +40 275/30 (no rubbing with rolled rears)
Zero out the camber in the rear and leave the front on natural camber. I had planned to do this with my previous wheels (8 +37 235/35 and 10.5 +43 275/30) but I ended up selling them before I bought my camber correction kits and rolled my fenders. I can post pics of my old setup if you like? I'm a little lower than you though.
I'm not talking about the bumper tab, I'm talking about the piece of metal that's more towards the middle of the wheel well, and The plastic bumper support mounts to that. I'll try and get pics later.
Would love to see pics of your old setup with those specs
Front: 19x8 +37, 235/35/19
Rear: 19x10.5 +43, 275/30/19
This is with natural camber at that height, after an alignment with the OEM equipment. The top half of the sheet were the readings before the alignment, the bottom is after.
Thanks for the pics!
The rear looks pretty good... do you think I could go with a +35 and still fit a 275/30 with only a fender roll? or should I go with +40? Is the 5mm more even going to make a visual difference?
Updated Specs
Front: 19x8.5 +35 with a 235/35 tire
Rear: 19x10.5 +40 with a 275/30 tire
Just want to make sure that these will give me a good, flush look and will only need a fender roll.
Thanks for all the help!
Updated Specs
