07 IS350 ENGINE STOPPED while driving on highway. Need your help..
Hello everyone,
First of all, I gotta say I very much appreciate all the valuable insights here on the this great forum.. I started doing mods by learning stuff from here.
I just had a very devastating experience with my 07 IS350 last night and I thought I should share this experience with everyone. Just so you know my car only has 80,000 km on it. Had every recall done at lexus dealerships and followed maintenance schedule. I purchased an ECP when I purchased a car which just expired last October... there goes my luck
Now to the point, I was driving on highway last night and all of sudden the engine literally stopped operating. The VSC check light and check engine light came on immediately. I barely managed to pull over on side road but the car wouldn't start. I started googling on my phone and tried all the tricks but it didnt work. Later the car started but the engine was making very weird loud noise.. like sth inside the engine was banging or knocking.. I ended up getting the following codes:
Camshaft sensor B, Camshaft exhaust sensor B, Crankshaft sensor B and multiple misfire...
I started getting abnormal engine noise a day before this happened but it was weekends and I was planning to take it to a mechanic on Monday. The car is basically not drivable at all.. as soon as I put it in reverse or drive the car dies.
Now looking back what happened last night... I could have run into serious trouble. I almost feel like I am lucky to be alive. I hope that no one here suffers from the same problem.
Has anyone had a similar situation? I also did a lot of research about similar problems but couldn't really find much info. Do you guys think it is best to take my car to the dealership although I dont have warranty on this car anymore?
Any input would be greatly appreciated. Thank you for your time reading my post.
Those noises you heard, was it a loud knocking noise that increases in sound when rpm rises? For example: when you start your engine, does the sound/engine noise increase significantly when rpm goes slightly higher?
idoke1,
Yes... I believe the sound gets louder as the rpm rises.. When I was able to drive the car, the noise was getting louder as I accelerate and getting quieter as I let go of the gas pedal. Thank you for your input.
Sick350F,
The last thing that was done to the car was just both front and rear brake pads and rear rotors... I checked the oil and its good... still there.
See5,
Yes, camshaft recall was done a couple months ago. Thanks for your reply.
Sick350F,
See5,
idoke1,
I actually looked for any metal flakes with the oil but the oil was good... my mechanic also confirmed that too..
Thank you idoke1.
See5,
Sorry my mistake... Just called the dealership and turns out it was a vvt gear assembly that was replaced. They said there is no recall about cam gears which I find it very funny.. I am located in Canada though..
Thank you idoke1.
See5,
mandyfig,
Yeah that is what I am thinking too.. I actually called Lexus Canada to file a report. Waiting for the manager to call me. They better realize how serious it is.... Thank you for the reply.
That's disturbing.. When I had my car at the dealership for a water pump replacement, I asked them about the common carbon build-up issue for the IS250, and they had no record of such an issue. WTF Lexus Canada...
Lexus of (Insert other Countries here) haven't had enough reports to process a state/country wide recall. Lexus of America on the other hand HAS had enough reports to do so. This happens a lot in other countries compared to America. There was a post a few weeks back of a guy who clearly had all the symptoms of the Carbon Buildup Issue but he was somewhere in the middle east and there are no recall reports of carbon issues in these cars at Lexus of (what ever country that was). I believe he had to pay the whole thing out of pocket
You would think so but its all a money game after that. The global recalls have to come from the big boys Toyota Motor Corporation. Anything under really depends on the market. I know UAE has some of the lowest number of recalls per vehicle because the majority of people there are wealthy enough to either fix the problem or buy a new one lol. They even have some recalls that aren't even available here in America.
Bottom line, TOW it to your selected Lexus dealer and have them pull the VIN. They should see what has/has not been done to it and work from there. It sounds like top-end damage to me.
DO NOT DRIVE IT!
GL!
