Outgoing Call ID showing Blocked
Old 04-17-14, 10:17 AM
snook
snook's Avatar
Default Outgoing Call ID showing Blocked
Has anyone else experienced this problem?
My moms outgoing call ID is showing blocked.
Each time she calls from the car or anywhere near the car, even while she's in the house her call ID comes through as BLOCKED when she calls people.
This is with an Iphone 4 if it matters.
Has anyone else experienced this and how do I correct it? Also is there a way to have it disconnect when the car is off and in the house? I cant believe the calls still come through if it's really going through the car, weird.
thanks for any adivce
Old 04-17-14, 10:06 PM
my1s250
my1s250's Avatar
its not the car there a setting on the phone and you must of switch it off.....go to setting,phone,show my caller id see if its off then turn it on.......and for the audio with the car off is normal it will last for a minute or so if its annoying then when you shut the car off and want to make a call just hit audio and choose iphone or when you make a call it should pop up and ask you which audio source you want to use it should be BT speaker,iphone,speaker...
Old 04-18-14, 11:11 AM
sktn77a
sktn77a's Avatar
The phone automatically disconnects from the car when the ignition is off. If the phone is in range of the car and the ignition is turned on, it will connect and go through the car.
Old 04-21-14, 09:11 AM
snook
snook's Avatar
That doesn't make sense though because when she calls from outside of the car I see her phone number. It's only when the call is made through the car that it is blocked.
Does anyone else know?
Thanks
fstyls
11-10-21 07:26 AM
riwyle
RX - 4th Gen (2016-2022)
11-10-17 01:00 PM
murfman89
12-16-16 06:43 PM
nfordhk
05-30-16 07:52 AM
bdar
ES - 5th Gen (2007-2012)
11-05-10 10:32 AM
Quick Reply: Outgoing Call ID showing Blocked
