In progress iPad Air dash mod
#91
its too late now but I would of cut out or slimmed down the main vents this would of giving you more room to maneuver and giving you a more stock look. and to avoid the head ache of the sound just gone with bluetooth for audio. Here is mine, it was my first crack at it, I will redo it with an Ipad air and a float mount kit later on, but for now it works great.
[IMG]https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/960x540/80-10401460_10204066556318932_47256193617071078_n_c8a145522f37721486955946c59f177a8065fac6.jpg[IMG]
#92
Well yes the main vents hit the back of the ipad which help keep it cool. And in hot weather and the ac still works great I have not noticed any change because I never really liked the air blowing directly in my face. I did try it for a hole week before I cut them off using the side vents only and it worked fine so I did it. Now I know what your thinking what happens when you wanna go back to oem well the original vents are intact I just bought a used vent from the junk yard for $15 and cut it up I can take the hole set up back to stock no problem.
#94
Well .. it's still in progress ... There's a bit of work to be done. I gotta make a video about this when I have some time.
I gotta figure out why the airbag lights are on in the gauge cluster, and why the passenger seat belt light seems to be behaving backwards
It's either the ribbon cable which connects the hazard button to the car has an issue, or there is something in this dash that's "different". ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
l
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
l
from a different car or is it your original. i had the same issue when i did mine cause i bought it
on ebay so i had an extra one. when i was modding mine i used the one i purchased and it did the same thing yours did. so when i finished mine i made sure to use my clock. no airbag light on. when i use the other one i bought it stays on. just letting you know incase you are not useing your orginal clock.
