hood won't close?
Old 04-25-14, 05:03 PM
dfwjohnd
dfwjohnd's Avatar
Default hood won't close?
Installed a F Sport grill on my 2011 is350 and now hood will not close.
Tried:
-Holding latch from inside the car open and hood down then releasing the latch.
-Latch seems to be in working condition
-Greased up the latch
What now
Old 04-25-14, 11:28 PM
LexusGuyyy
LexusGuyyy's Avatar
I'm assuming you didn't shift or remove the hood? Try seeing if you accidentally lock the latch before putting down the hood, if you lock the latch before the the shutting the hood it will just keep hitting the latch, I'm not sure why would a grill would cause the hood not to latch. Second, try seeing if the hood latch in the car isn't stuck causing your hood to stay open, update us when you find the problem.
Old 04-26-14, 05:58 AM
mandyfig
mandyfig's Avatar
Old versus new grille, identical in size?
Old 04-26-14, 09:52 AM
dfwjohnd
dfwjohnd's Avatar
Yes, it's an oem grill
Old 04-26-14, 10:39 PM
dfwjohnd
dfwjohnd's Avatar
got it to close once, got home to try to fix the problem now it will not close again. I'm not interested in just closing it; I want to fix the problem
Old 04-26-14, 11:17 PM
LexusGuyyy
LexusGuyyy's Avatar
Try installing the old grill and see what happens that will let you know if your new oem grill is compatible.
Old 04-27-14, 09:41 AM
NYKnick101
NYKnick101's Avatar
Make sure the plastic engine covers are not on the hood bump stops.... that is a common thing that is overlooked
Old 04-27-14, 10:53 AM
dfwjohnd
dfwjohnd's Avatar
I wish this was it, thanks for the post though
Old 04-27-14, 11:05 AM
liqB
liqB's Avatar
Can you take a pic of your install, maybe we can spot the problem for you.
Old 04-27-14, 03:27 PM
dfwjohnd
dfwjohnd's Avatar
would the weatherstripping above the grill could have caused this if it was re-installed facing the wrong way? Not the wrong way meaning upside down... All of the "clips" snapped in place...
good idea, will do this when I get home.
twobrains
RX - 1st Gen (1999-2003)
10-18-22 05:06 PM
stevies30
07-11-16 11:28 AM
SC3coupe
SC- 1st Gen (1992-2000)
01-28-15 04:38 PM
SC3coupe
08-14-13 07:43 AM
Iansaltes
12
09-06-11 08:40 PM
Quick Reply: hood won't close?
