Hey guys, I had the track wheels installed on my IS250 in May and have been too lazy to pictures up, right now I'm on my winter wheels so I decided to get the tracks powdercoated gloss black. Above are pictures of the wheels the day I had them put on, then with plastidip which I later took off and finally with the gloss black powdercoat. Can't wait to put them on when it warms up! By the way sorry for the crappy pictures, I didn't intend to post these on the forums but I thought you guys would like to see so here you go! Also, I made custom center caps to match the wheels, let me know what you think. I still gotta lower my car!
Can someone link me to black lexus center caps that would fit on the track wheels? Something similar to the picture I have below. I want them to match the gloss black wheels!
Yes the OEM lexus TPMS sensors work fine with the track wheel. Here are some pics with the wheels on that I finally got a chance to take! (Yes I know, I have to lower the car asap!)
keyur246, what size tires do you have?
And is this a RWD or AWD? I'm planning on getting these rims, but not interested in lowering. I know the AWD sits a lot higher than the RWD so i'm hoping this is AWD
Reason: Missing end [/Quote]
Im running 235/35/19 all around and yes it is AWD.
^I'd not chance it. I've not read about someone having done so; not saying it couldn't be done, but cross-reference the part # of the unit to see if they work with the 2IS as well.
I have an AWD Is250 with is350 brake calipers up front. I dont want to stagger due to awd, and Id rather not use spacer to clear the calipers. Couldnt I just get 2 pair of rear geneis wheels?
^Yes, you could; however, you'll still run into the caliper clearance issue since you have IS350 calipers up front. The concave design on both wheels are VERY similar. and I fear the rear will still have the same issue as the fronts.
What square tire setup are you thinking of running?
where are u guys finding these i cant find them anywhere
Online classifieds (site called Kijiji for Ontario). Took me over 6 months to find a pair for the right price.. Tire change over season is probably the best time to look. You might get lucky to find a pair on gencoupe classifieds.. good luck!
