***OFFICIAL Genesis Track wheels on a 2nd Gen IS thread***
Old 12-14-16, 09:04 AM
  #91
Spricky
Spricky's Avatar
Originally Posted by TophersToy
The fronts rubbed a little. I heated up the liners and pushed them back. This was on an RWD which sits a little lower than the AWD
​​​​​​​aah okok.. Thanks for the help
Old 03-28-18, 05:32 PM
  #92
wickedik
wickedik's Avatar
I know the original post said we need at least a 5mm spacer to get these to clear is350 calipers, does that mean like 7mm or 10mm? I'm trying to to go too big of a spacer if i don't need to .
Old 03-30-18, 10:03 AM
  #93
Gville350
Gville350's Avatar
You could probably get away with a 3mm spacer really; but with thermal expansion, I'd go for the 5mm. I've been running a 5mm spacer on all four corners since I made this thread. Always used a torque wrench when installing the lug nuts, and have never once had an issue. Post your pics after install!
wickedik (03-30-18)
Old 03-30-18, 04:57 PM
  #94
wickedik
wickedik's Avatar
do you use extended studs?
Old 12-18-19, 08:52 AM
  #95
dk303
dk303's Avatar
I have a set of Genesis 19 track wheels with tires for sale I can ship. Lmk.
Old 08-17-20, 07:51 AM
  #96
Spricky
Spricky's Avatar
Originally Posted by kennytbone
All those numbers are tire sizes. Wheels are measured in diameter, width, and bolt pattern. These wheels are 19" diameter by 8" wide in front and 19" diameter by 8.5" wide in rear and will accept a partially overlapping range of tire widths. The 8" wide wheel will (ideally) accept tires between 215mm and 245mm wide and the 8.5" wheel will (ideally) accept tires between 225mm and 255mm wide.
So one could run 235 tires on all four wheels or 225s in front and 245s in rear.
Another noob question.. If I ran a 235 on all for tires even though the back rims are 8.5" wide.. Would that still be considered staggered? 🤦🏿‍♂️
Old 08-17-20, 12:05 PM
  #97
primavera
primavera's Avatar
2010 IS250 RWD. 225/40/19 F, 255/35/19 R. Stock Suspension
The car should've came with those tire sizes from the factory. Proper look and totally acceptable ride comfort.
Old 08-17-20, 02:23 PM
  #98
RX469
RX469's Avatar
Those wheels turned out great and they look superb on your car!
Old 08-18-20, 11:15 AM
  #99
Gville350
Gville350's Avatar
I guess that depends on who you ask. But to me, a staggered setup is having narrower tires up front vs the rear.
Old 08-23-20, 11:27 AM
  #100
Spricky
Spricky's Avatar
Lol, makes sense, thank you
Would a staggered set up change the way the car drives?
Originally Posted by keyur246
Im running 235/35/19 all around and yes it is AWD.
I'm thinking of running the exact same set up, as I do own an awd is250. How's the drive?
Dexterr
06-28-20 06:15 PM
RDIS250AWD
09-10-14 09:45 PM
MyC4LS
02-27-11 07:52 AM
sashax415
06-15-06 01:08 PM
Quick Reply: ***OFFICIAL Genesis Track wheels on a 2nd Gen IS thread***
