Is350 calipers
Is350 calipers
Alrite guys, i know this is an old thread but i cant find the old thread / file for is350 calipers on is250.
I just got the is350 calipers it self & i want to install it on my is250 .
What others parts are need to do this calipers upgrade on is250 ?
If possible complete & details .
Thanks & hve a good day .
You should be searching a bit more before making topics about everything.
https://www.clublexus.com/forums/is-...ml#post8391705
The DIY is out there too, but it's really very simple enough where you shouldn't need one...
You should be searching a bit more before making topics about everything. https://www.clublexus.com/forums/is-...ml#post8391705 The DIY is out there too, but it's really very simple enough where you shouldn't need one...
Thumbs up 👍
Bro you need the 350 brake dust shield and rotors that will fit the 350 calipers.... save you time from all that reading
Brake Pads (04465-30410 - Textar T4146 High Friction or 04465-30450 - NBK D6893H Low Dust)
Brake Pad Shims (04945-22152)
Brake Pad Anti-Rattle Clips and Retaining Pin (04947-22070 and 47735-50020 x 2)
Brake Rotors (43512-22260 and 43516-22010 - RWD Only, 43512-30350 and 43516-30040 - RWD or AWD)
Brake Backing Plates (47781-22200 and 47782-22200 - RWD, 47781-30240 and 47782-30240 - AWD)
Bro you need the 350 brake dust shield and rotors that will fit the 350 calipers.... save you time from all that reading Brake Pads (04465-30410 - Textar T4146 High Friction or 04465-30450 - NBK D6893H Low Dust) Brake Pad Shims (04945-22152) Brake Pad Anti-Rattle Clips and Retaining Pin (04947-22070 and 47735-50020 x 2) Brake Rotors (43512-22260 and 43516-22010 - RWD Only, 43512-30350 and 43516-30040 - RWD or AWD) Brake Backing Plates (47781-22200 and 47782-22200 - RWD, 47781-30240 and 47782-30240 - AWD)
Thanks
Also I know this method works for a fact as I did it on my old IS250.
awd_love
09-16-09 06:26 PM
