Driver side headlight problems...need help!!!
Old 05-05-14 | 11:42 AM
Gerod77's Avatar
Gerod77
Default Driver side headlight problems...need help!!!
Ok here is my dilemma..........I have a 2006 IS350 and the driver side headlight will turn off while driving and when I switch them off and then back on it'll come back on, but then it'll go off again after a while. Its been doing this for a while now and was wondering if replacing the bulb will fix the problem. The problem happens both on high and low beams and also if I have the headlight switch on the auto or on position. Has anybody experienced this before and if so, how did you fix the problem. Another question is.........how will I know if I have regular bulbs or HID's on my Lexi? Is it hard to replace the bulbs on them?
Old 05-05-14 | 12:13 PM
nippiexfam's Avatar
nippiexfam
I would first attempt to swap your passenger bulb to the driver side and vice versa to diagnose if it's a bulb issue. Halogen or HID is the same process.
Old 05-05-14 | 01:16 PM
Gville350's Avatar
Gville350
^Agreed! If the symptoms follow the bulb, then replace the bulb. But judging by what you posted and previous threads on the matter, most ended up being a faulty ballast. <---This being if you have HIDs.
Old 05-05-14 | 01:20 PM
afusco1222's Avatar
afusco1222
I'm having the same problem. If you find a solution please post it up here.
Old 05-05-14 | 01:21 PM
tex2670's Avatar
tex2670
Easiest way to know if you have HIDs on an '06 is that you also have AFS. If, with the car on, and stationary, you scroll left or right on the button that looks like this: [<O>] to the left of the steering wheel, AFS On/Off will be an option if you have HIDs; but not if you don't.
You say it happens on high and low beams. If you have HIDs, then your high beams are both the HIDs, but also the DRL bulb. If both of these are out, I don't see how your issue is just a bad bulb or ballast.
Old 05-05-14 | 02:06 PM
Gerod77's Avatar
Gerod77
Thanks...I'll check on that and keep u guys posted
Old 05-06-14 | 09:06 AM
Gerod77's Avatar
Gerod77
I swapped the bulbs around and YESS it was the bulb. Called dealer and they want $160 per bulb and since I wanna replace both ...too much money for a freakin bulb. I purchased a PAIR of bulbs from ebay for $40. I read all the reviews on them and seem good.........HOPE they work and last
Old 05-06-14 | 09:11 AM
Gerod77's Avatar
Gerod77
Default Good bulbs or not???
6000K D4S XENON HID BULBS DIRECT REPLACEMENT FOR PHILIPS & OSRAM
These are the bulbs that I purchased, does anybody know of they are good bulbs atleast worth installing .....thanks in advance
Old 05-06-14 | 10:16 AM
maddnotes's Avatar
maddnotes
Default Same problem
I had the same problem happening to me. I had a set of Garax bulbs laying around so I threw those in to see if it fixed the problem and so far so good.
Old 05-06-14 | 01:27 PM
Gville350's Avatar
Gville350
Provide a link to the listing.
Jaybeck860
IS - 1st Gen (2001-2005)
01-28-14 12:08 AM
ecko1211
09-03-13 11:53 AM
gwagon63
IS F (2008-2014)
04-03-13 03:11 PM
GaryP123
08-24-12 08:42 AM
CJITTY
09-14-11 07:13 AM
