oil overfill?
Just got an oil change at a new spot today. After I left I noticed they charged me 8 qts. I know it only takes 6.5-7. I check and sure enough its about a cm above the top fill line. Is this bad? Is there an easy way to just take out a little oil without making a mess, or should I not even worry about it?
That much of oil over the limit, I would remove it. Simple way, get a syringe and the long enough tube and inset into the oil dept stick, and suck it that way. If u don't have it, you can get the oil change pump kit from Walmart, or any auto store. you can always use it later to remove and replace the brake and power steering fluid, or even the differential oil change.
Good luck.
Check with the dip stick. Use a pump or syringe. They might have used extra oil to flush out more of the old oil, but I never heard any place doing that (only people who change their own oil).
Or they might have not change the oil in the first place if you took it to a shaddy place.
I would definitely get it removed. Oil overfill is much worst than low oil; the extra pressure can burst out at a random location in your engine.
Cheapest way to remove it is to just unscrew the oil filter housing a little bit. Removing the oil filter removes a maximum of 0.5 qts.
Hopefully they just accidentally billed the wrong amount of oil (not uncommon when i worked in a dealership).
The parts guys would always bill the oil before the tech filled his oil jug and for some newer parts guys it wasnt uncommon for them to get the oil quantity wrong for some models. I never had a tech overfill a car because of the parts dept billing it wrong.
Now if it was a private shop, both the parts and tech could have gotten it wrong and billed too much and filled too much oil.
Check the oil level..if its good, call them ask for some $$$ back or a credit for the next oil change if you plan on going back.
Thanks. I hope they changed the oil they seem reputable but I will inspect and try to figure that out. I think I'll try the syringe/Walmart option first, as I don't have the filter wrench. But I'm thinking I'll be getting one of those soon too. On second inspection it is actually a little less then 1 cm above top fill line, but still don't want yo risk anything. Thanks again
Ok so i couldnt find anything at walmart, and just went ahead and ordered the filter wrench. Does anyone know, if i remove the filter while the car is still full of oil, is all the oil going to run out? or only the 0.5 qt in the filter?
Are you sure they overfilled your car???
Places that do it right charge you an extra quart to flush out your old oil. Our cars take in 7 qt.
If your car is not sluggish ( when I mean sluggish I mean slow *** Pho..ck) and you are not putting out white smoke from your exhaust then you are okay, no need to worry.
Seems excessive or just a money maker for a shop unless the engine seems to be a sludge monster. (and even then thats useless)
Another idea I always do it .....open and remove the oil drain plug 2 seconds and re-plug it....hand tight ....check the oil level.....and open it again if it necessary ...torque it when you finish .....it's need fast action...that's the cheapest one
Do it while the engine is off.......and better when the engine is cold so you not hurt your self with the hot oil
Over fill oil level cause seals leaking or ruptured on high RPM specially the harmonic balancer or the rear engine O seals .
Sorry forgot to mention I use the extra from my 5 qt containers since I buy 2- 5qt containers at a cheaper price.
BUT there are some shops that do rip off and charge for 1 more qt when they only use a less than a qt to flush the old oil and say that for whatever reason that they "supposedly cant re-use the oil" or whatever BS excuse they give to make a quick buck.
Gville350. NO overfilling is not okay thats why I said that maybe that shop used 1 quart or less to flush the old oil out and charged him for 8.
