IS350 JoeZ PTS Exhaust Install
IS350 2008: Installed the JoeZ PTS exhaust (w/o cats) over the weekend. Great build quality, amazing sound, great cost.
I do have a few of gripes, none that at this point are insurmountable or major
1) Drone: drone exists at lower RPMs (cruising), and when slightly on the excellerator (wifey seriously dislikes)
2) Rattles: multiple spots rattle on heat shields. This changes with car temps and road condition
3) Clunk: the exhaust drops down and hits the perpandicular brace on moderate bumps.
4) Driver side muffler: pops up and hits what appears to be a frame/body mount on large bumps or "bouncy" road consitions. The stock muffler had a dead weight on it, I imagine it was there to avoid this.
5) Bolts: did not come with new bolts for initial connection to the primary cats.
Solutions to try:
1) Drone - without modifying the actual exhaust, suspect there is only adding pillow packing in spots in the trunk, or dynomatting the trunk and back seat (in the trunk).
2) Rattles: have bent some out of the way, will need to do more. (it's not stones rattling around)
3) Cross brace clunk: going to add some washers between the body and the brace to lower the brace to allow more clearence
4) Driver side muffler: not sure what I can do here. Maybe add a rubber item to the mount so it's not metal hitting metal.
5) Bolts: simply re-used the existing ones which was likely the plan anyway.
If anyone has any other ideas for the drone (or any others), would love to hear them.
Cheers!!!
Solutions to try:
Cheers!!!
