Red ! On dash when driving is that flat key battery ?
Hi just seeing if the red ! Triangle came on normally goes out after starting but it didn't then I stopped turned the car off then it would start I pushed the buttons on the key then it went and light didn't come back on any ideas I went and got new batteries for the remotes but not sure if that is the problem thanks
The red "!" (exclamation point) indicates low tire pressure on one if not some of the tires.
Not necessarily. It only means that when "LOW TIRE" comes up in the display and amber tire icon is lit. It also comes up when an oil change is required, the check engine light is on, or any of a myriad of different reasons.
I had same thing happened this morning. Right after I put into park after got to my office parking lot. That red triangle blanking for like 10 seconds. Then I shut my car off restart again. The red triangle gone. What give?
The red triangle is telling you something is wrong, it does not tell you what is wrong. You need to read the message on the display. It could be low washer fluid, low tire pressure, etc.
Sorry for hijacking this thread, I was going to post a new one but it is similar to yours OP. This morning I got an orange _!_ warning at the bottom right of the dash.. Anyone know what this means?
Usually when you get the red triangle, there's also a warning in the multi display that tells you what's wrong.
Did you read any of the prior posts in this thread???
what is the error "Washer Fluid low"? what dose that mean?
Haha...It's telling you your windshield washer fluid is low. I hate that warning because it makes it look like a serious problem. And it's so annoying it forces me to refill it just to turn it off!
