IS350 fuel trim problem-Update
Hey guys,
Just wanted to update you regarding really high positive fuel trims (running lean). It turns out I had a crack in the exhaust pipe right after the post cat 02 sensor. There is a heat shield there that causes the pipe to rust and crack. I had my exhaust shop weld the crack shut and I checked the fuel trims. They're returning to normal now! Hope this helps anybody who has a strange fuel trim problem. The rear 02 sensor can command up to 10% additional fuel trim!
Nad1370
RX - 1st Gen (1999-2003)
04-28-10 04:38 PM
