2007 Lexus IS 250 won't start after rotating tires
Old 07-05-14, 05:25 PM
lindajl
lindajl's Avatar
Default 2007 Lexus IS 250 won't start after rotating tires
SOOOOO, my hubby today changed my oil and rotated the tires. Now the car won't start, all warning lights are on including check engine VSC, traction control etc. Called Lexus, they said have it towed in, we don't know. Nice. Anyone else have this issue. In ran fine when he pulled it in to do the work.
Old 07-05-14, 11:17 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Welcome to CL. Sorry to read about your issue. This could have been answered earlier but you posted in the build thread section. Have you tested the battery? The work performed has nothing to do with the car. Foot in the brake and key fob in the car?
Old 07-05-14, 11:36 PM
darkdream
darkdream's Avatar
The work has nothing to do with the problem. Even if your husband forgot to put oil in, the car still would start.
Old 07-06-14, 12:26 AM
jst17
jst17's Avatar
rotating the tires has nothing to do with the car not starting.....The lights are supposed to stay on until the car has started. You could attempt to hook it up to an OBD scanner, but it is most likely a battery issue.
Old 07-06-14, 12:27 AM
LexusGuyyy
LexusGuyyy's Avatar
The battery could be low enough to turn on all accessories but not turn over the car, try changing the battery before Lexus charges you some ridiculous price that could have been avoided.
Old 07-06-14, 06:22 AM
lindajl
lindajl's Avatar
thanks for the replies. Battery is good, car ran fine before work was started. Key fob is in and foot on the brake. When we can get the car started it won't go over 2000 RPM's or 20 MPH.
Old 07-06-14, 08:29 AM
ISFWes
ISFWes's Avatar
Default Limp Mode
When he was doing the work he may have left the car battery on. And it discharged the battery down. Did you try to jump it after it wouldn't start? The fuses may have blow when the cables were hooked up backwards by accident.
If you know you have a good battery. Disconnect it and let the ECU reset all of the codes. Then hook it back up and try starting it again. Then try the fuses.
Good luck
Old 07-06-14, 10:07 AM
nosurprise
nosurprise's Avatar
You check the oil level is good after the change? You didn't drain the wrong oil (not sure if you can do it on the IS, I know people had done it with other cars)?
Old 07-06-14, 10:20 AM
darkdream
darkdream's Avatar
Possible carbon build up?
Old 07-06-14, 11:00 AM
knbnguyen
knbnguyen's Avatar
sound like the air intake is loose.. check to make sure all the seal and everything on the air intake and tube is all sealed and connected properly.
Old 07-06-14, 01:05 PM
marcsis250
marcsis250's Avatar
sounds like above. probably unplugged something or pulled on accident. weird though since you don't need to remove anything with hoses or wiring to change the oil.
yumcax
Hybrid Technology
14
02-14-17 09:44 AM
mackel53
10-04-16 05:36 PM
Farbound
Performance & Maintenance
05-14-14 09:30 PM
jwhite125
ES - 5th Gen (2007-2012)
01-24-12 12:40 PM
Quick Reply: 2007 Lexus IS 250 won't start after rotating tires
