Urgent Waterpump O Rings
Old 08-04-14, 04:09 PM
lexus-is2
lexus-is2's Avatar
Default Urgent Waterpump O Rings
When changing the water pump, it comes with 2 new O rings. One for the water pump and the other for the water inlet part. However, having changed everything and tried to bleed to system, it sprung a leak through the small O ring of the inlet unit. removed this unit to notice that somehow the O ring had cut on it at the bottom. The leak only sprung after coolant reached temp and was running for a while. So I can only imagine that maybe there was some kind of cut on the O ring which expanded as coolant temp went up.
it's the small O ring pictured here:
Anyway, i'm now in a dilemma, I still have my old O ring which looks in good condition, do I just use that or should I contact Lexus and see if I can get replacement O rings?
Old 08-04-14, 04:39 PM
minato
minato's Avatar
I would wait and get to the dealership to get new orings
they should be no more than 5$
Old 08-04-14, 06:16 PM
toyoman29
toyoman29's Avatar
I would also wait and get them from toyota or lexus and put a very light coat of grease on them after installing.
Old 08-05-14, 06:14 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Do it right and put the new O ring in. Otherwise you could be doing this job again if your old O ring messed up later.
Old 08-05-14, 10:50 AM
lexus-is2
lexus-is2's Avatar
Thanks for the replies guys. Getting new O rings from Lexus tomorrow. Hopefully this one goes well. I will be replacing both the small and big O rings. Even though the big O ring is new, but i had to loosen and remove the unit to access the small O ring, so best to change big O ring too.
DCLyles
06-12-17 06:05 AM
Willmkent
21
08-12-14 04:31 PM
Baetke
RX - 1st Gen (1999-2003)
11-13-13 07:51 AM
Patsum
07-27-12 04:29 AM
Colpup ES3
12-14-07 10:09 AM
Quick Reply: Urgent Waterpump O Rings
