help 08 ML audio system
Hi, I have done some searches and only found a similar post before, but no solution. I have a ML audio system and after a battery replacement, the CD changer doesn't work. The load/eject button does nothing and the screen shows "NO DISC" when the changer is loaded with 6 CDs. I'm not sure if it's a security feature that locks out the audio system ? or fuse ? The battery was disconnected for a day. The radio works and other functions works.
I also have DVD-R and CD-R mixed with original sound track CDs in the changer, and these plays before until the battery was replaced.
Does anyone know a way to eject these discs in the changer besides manually take out the unit ? or is there a "Shipping Mode" on the unit that can eject all the discs like in the RX model ?
tks.
tks.
I read one thread where someone pressed the eject button or tired the "load" function and started feeding in another CD...but only slightly into the slot. Somehow that forced the system to eject all of the disks.
Perhaps some searching on here will bring up that thread.
GL!
GL!
GL!
GL!
here is another thread that I just found. the CD player had the exact symptoms as to mine.
https://www.clublexus.com/forums/is-...t-working.html
