Need some help with error codes? on my lexus is350
hi guys
my name is sveinn and im from iceland
i just bought a Lexus IS350 2006 (One of only 3 in Iceland) lol
and i got theese error codes:
DTC C1223 ASB Malfuncion
and
DTC C1225 SA1 Solenoid Circuit
can anyone tell me what they mean?
thanks
and
thanks
Found this for DTC C1223 ASB: http://www.justanswer.com/toyota/1y1...ning-code.html
http://share.qclt.com/%E4%B8%B0%E7%9...em/0370018.pdf
The other one: http://www.moranbahweather.com/toyot.../m_di_0233.pdf
http://st.club-lexus.ru/attach/u/fbb1b2c5.pdf
Good luck.
Good luck.
Good luck.
Good luck.
I know the 2nd one maybe a loose ground, loose connection, or a short. I'm sorry I cannot help you because I am not familiar with those codes. All I can say is look for the 2nd issue. If found and fixed, the 1st issue may be resolved too. I remember back when my 03 camry had all types of codes that came up. Alot of those codes mentioned circuit. Spent alot of money on sensors and it still did not fix anything. I then found a loose ground wire and after tightening that up, all codes were gone and the car ran good with no service lights. I wish you the best.
NR1DAD
IS - 1st Gen (2001-2005)
08-25-14 02:42 AM
