Possible ECU Remapping for IS250/350?
#211
#213
I hope someone with 350 f sport tries this out. I'm curious to find out how to activate the tuned map using the different drive modes. Will the AVS be activated if the ecu is overridden.
#215
order directly from http://www.vrtuned.com and you get the 10% discount
#219
Does anyone know if there are ANY other 2IS's that have tried this???? I am local for Vivid and will be doing some research as to how long this "flash" is lasting. I am not convinced the car is staying "flashed". Every other "flash" has failed and the car has autocorrected back.
I'd like to see a dyno after 5000 miles or so to see if the car holds the "flash"
#220
I did not intend it to be demeaning. If someone buys a high mileage car chances are they don't want to drop a bunch of money into it. I am cheap when it comes down to my high mileage S2000 which I purchased used from a family friend to used as a beater.
#222
Let's stay on point..
A. Why does this dyno sheet appear WAY high?
B. What makes this different from every other "flash"?
C. Has there been even ONE other IS that has used this product?
I live in AZ and have some friends, that know some of the Vivid people, inquiring personally to find out how legit it is.
Has anyone on here had any personal experience with VRTuned products?
#223
I found something on Vivid racing. I hope its not too good to be true
http://www.vrtuned.com/shop/ecu-tuni...dbr7b6k81j8b67
#225
