Possible ECU Remapping for IS250/350?
Old 11-07-14, 11:30 AM
  #226
RSXiMUS
RSXiMUS's Avatar
So how exactly does this "auto tune" work?
Is it basically tricking the computer into thinking the weather is cooler, air is denser ect?
So the ECU will switch over to a more aggressive map, advance the timing, run a little bit leaner ect.
Kinda like a more sophisticated version of those so called "ebay chips" that you use to fool the ECU?
Old 11-07-14, 11:46 AM
  #227
Rickna
Rickna's Avatar
No. VR claims that there are higher performance map(s) in the ECU and that their device can access and apply it (them).
Old 11-07-14, 11:48 AM
  #228
daileycon
daileycon's Avatar
Originally Posted by AZ JB
All of these threads need to be merged.. too many to keep up on!
Agreed! ......
Old 11-07-14, 12:46 PM
  #229
JB5674
JB5674's Avatar
And that dyno sheet seems way high for an IS350 with only a cat-back exhaust (pre "flash").. C'mon mannnnnn.. ~300WHP basically stock?
I'm staying extremely skeptical for the time being..
I spoke to vivid. They basically said I could return the unit and get a full refund prior to 30 days. I'm with the guys above. How long does the tune hold. I can't find any reviews for lexus online. A lot in vw and Porsche and it seems to be legit. But turbo vs na comes to mind. I built a g37s and never got 20 whp numbers from the mods. Another 10plus would be good but thI'd statest 20hp and 40tq. I'm not completely sold
Old 11-07-14, 12:52 PM
  #230
RSXiMUS
RSXiMUS's Avatar
Interesting..... I wonder if our cars ever use these "high performance" maps in any given conditions...
If not then I wonder why they were loaded in the ECU in the first place when they're never used.
I'm a bit skeptical that somehow VR stumbled upon a way to enable these super maps...
I really hope it's true though, I would love to buy it for my IS-F if it really did work.
Old 11-07-14, 01:02 PM
  #231
Rickna
Rickna's Avatar
This should give you some answers- http://www.vividracing.com/catalog/v...150794665.html
Old 11-07-14, 01:30 PM
  #232
RSXiMUS
RSXiMUS's Avatar
Thanks for the link Rickna, this does sound promising after all...
I would so buy it if it works on the IS-F, right now we are getting conflicting information on whether it's compatible or not..
Old 11-07-14, 01:55 PM
  #233
Rickna
Rickna's Avatar
Yep, we're all riding the emotional roller coaster...LoL
Old 11-07-14, 01:56 PM
  #234
tomiv9
tomiv9's Avatar
I've noticed simply resetting the ECU by disconnecting the battery seems to make the car more responsive. Could this be whats causing the change in dyno results instead of the chip? I mean maybe car's ECU had learned to drive somewhat slow, they tested it, then applied flash reset ECU, he drove hard for a week, and presto great dyno results
Old 11-07-14, 02:00 PM
  #235
Rickna
Rickna's Avatar
I believe the ECU is adapive, that's why the take a week or several hundred miles.
Old 11-07-14, 02:02 PM
  #236
tomiv9
tomiv9's Avatar
I know that's my point, maybe he just drove it harder the past week, then he did before the first dyno. Could that explain the gains?
Old 11-07-14, 02:06 PM
  #237
An2ny
An2ny's Avatar
I am a bit skeptical about this maybe the throttle response and faster shifting but I don’t see this making all that power. Hopefully someone can explain this better and we can get a real independent test.
So, it only works with automatic transmissions?
Old 11-07-14, 02:19 PM
  #238
CJW
CJW's Avatar
If that is for real, take my money.
I'm also skeptical to dynos by manufacturers, but this car could use a bump IMO.
Old 11-07-14, 02:29 PM
  #239
Larry96815
Larry96815's Avatar
So do we have any Club members from Chandler AZ? If yes, see if they would flash your car and dyno before and after. That could get them lots of sales....... or ...........
Old 11-07-14, 03:24 PM
  #240
smokyis350
smokyis350's Avatar
That doesn't make sense. Resetting the ECU will just change the throttle response and shift points. You won't magically have more power if you drive your car harder.
Quick Reply: Possible ECU Remapping for IS250/350?
