ECU Swapping Questions
I tried to search and could not come up with a definitive answer. I found these threads which were quite useful:
https://www.clublexus.com/forums/is-...ering-ecu.html
https://www.clublexus.com/forums/is-...vdim-work.html
So my questions:
What ECU's do our cars have? VDIM, Steering, Main, anything else?
All ECU's plug and play, interchangable between all years? Benefits of ISF ecu's if plug and play?
I want the 07+ Traction off 3 second hold vs my 06 pedal dance, is it possible?
I'm looking for specific info on my 06, and interchangability between all 2IS.
Thanks
So my questions:
Thanks
The 07+ skid control is part# 89540-53290 and will have a VT on the label... It is located under the glove box, simply remove the access panel to get to it, and it is held in place by 3 bolts. Very simple install... I will caution you that if you install it(in an 06), when you disengage traction control via the button you will get a warning message in the display screen that says "vsc test mode" and the red triangle with exclamation point. I have not been able to find out if the dealer can remove this warning.
Here is one for sale on ebay:
http://www.ebay.com/itm/Lexus-IS350-ABS-Skid-Control-Module-8954053250-8954053251-8954053290-/300872241520?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIS350&hash=item460d621170&vxp=mtr
Monique023
05-19-21 09:56 PM
Boofster
05-01-18 04:55 PM
JETLEX
03-06-17 03:03 PM
skottydznt
09-22-16 02:19 PM
