Windows are messed up
Old 09-01-14, 08:38 PM
sparta3993
sparta3993's Avatar
Default Windows are messed up
2006 Is250 ML Sport
Just got my GPS wire in and plugged them the other day. Gps is working great. Though now my windows stopped working again. For the first 2 months only the front windows would auto down and up from the driver side, but all windows worked from their own switch.
now only auto works for front driver and rear passenger. the other two windows work from their switches but are no longer auto.
Not a single clue what to do, have unplugged the battery several times for more then need, 24 hours..
note: rear passenger was not working until today. I am very lost please help.
Old 09-01-14, 08:57 PM
istarzan
istarzan's Avatar
You have to hold each switch on each door down or up forgot, for a few seconds to reset after battery disconnection. Do a forum search.
Old 09-02-14, 05:52 PM
Gville350
Gville350's Avatar
^To expand on what he was trying to say, you need to use each door's window switch and do the following :
1) Hold the switch down to lower the window all of the way
2) Keep holding the switch down a few seconds after the window bottoms-out
3) Immediately "roll" the window up all of the way and hold for a few seconds after the window is fully closed.
After doing this to ALL of the door's window switches, you should now be able to control the "express" settings from the driver's master switch.
Old 09-02-14, 06:54 PM
dtl
dtl's Avatar
https://www.clublexus.com/forums/is-...isconnect.html
Old 09-02-14, 07:16 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,305 Likes on 1,406 Posts
The above is also linked in the FAQ Sticky, a great first stop!
https://www.clublexus.com/forums/is-...iy-thread.html
momof1
09-12-17 04:41 PM
kevenhang
02-24-16 09:43 AM
Rsbaker
04-11-15 10:47 AM
lilthanh19
02-06-08 08:47 PM
Quick Reply: Windows are messed up
