Universal solution to clunking noise in bc coilovers (passenger rear)?
I guess it could be because the "pillowball mount" encompasses the use of a spherical bearing instead of a rubber component. The rubber could allow for that movement, while the pillowball mount wouldn't move. But does having the rubber mount make you have the clunk noise? That could be possible. If you have time, try moving the rear shocks from one side to the other to see if the noise follows the coil or stays there.
cr00klyn71
06-18-10 06:25 AM
