Fog lights are dead
If you only checked the fuses, then the next step is to check the bulbs themselves. There is a DIY thread illustrating the process to getting to them.
Now if the bulbs are bad, then it could be a relay issue (ones in concern would be the ones dealing with the high beams as the fogs go off when the high beams are engaged).
http://www.ebay.com/itm/291168963811
after i plugged them in they wouldn't turn on when i plugged the regular bulbs back in .... I checked both fuse boxes under the hood and the passenger side .... are the fogs on the driver side .... is there another fuse box there?
Shouldnt be... when I upgraded mine to hids it was a simple plug and play. I am wondering if u maybe fried the relay? Have you got a power tester to see if power is still running to the connection point?
Did you check the fuse under the hood? I believe there are multiple fuses to check and I would bet money that a blown fuse is your issue. Unlikely that both bulbs went at the same time.
When I put in HID fog lights, one of the ballasts went bad and would blow fuses the second I installed them. I believe the fuse was under the hood.
