One door not locking problem
My left rear door will not lock when the lock button is pressed. I have to manually push in the lock on the door. But the door will unlock fine when the button is pressed. Do you think my actuator is bad? Is it hard to take the door off to look at whats going on?
no lights turn on when trying to lock the door with the key fob. i have to manually push the lock in on the door to have the hazzard lights turn on when locking the doors with the key fob. Also is there any sensors in the door i need to worry about when replacing the actuator? like a air bag sensor?
