Radio noise
Hi I have a 2011 IS350 i purchased off lease and i really enjoy the car , recently I have noticed i have engine noise coming through the speakers its really aggravating . I have the navigation system and everything Im just seeing if anyone else has had this problem or could give me some advice on how to fix the problem . Thanks for any advice
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Its different at different times i know it sounds crazy but im maybe if bluetooth is connected its worse. thanks for your reply sorry it took so long to reply
Saying it is worse with Bluetooth, that is the exact opposite of what I was expecting. I had to install a ground loop isolater on my '06 model, since it only has a AUX cable port. It fully eliminated by engine noise coming through the stereo.
Your issue has me baffled if it gets WORSE using a wireless signal. Beyond my knowledge there.
I guess I'd start by making sure the grounds for the amp and the headunit are good and work from there.
