headlight adjustment
I've done the forum searches and know where the adjustment screws are for the HID headlights. Only question I have is which way do you turn the screw to adjust left and right. The previous posts weren't too clear IMO. My driver side one is currently pointing a little too far left, its noticeable when looking at the lens assembly.
It's located a couple inches further away from the vertical adjustments, almost up against the fender. Check this out
. I believe the video was posted by a CL member as well.
