Work Meister S1 3p or VSXX Cannot Decide
I will have 5-8mm poke so pretty much sitting flush. Would the Meister's O disk (deep wheel) fit up front or I have to go Standard Disk A? Need to clear front calipers.
ive always had a soft spot for VSXX but they kind of run into the ground on the 2IS honestly. I would go S1. get the lowest disk face if you have a 250 since you wont have to worry about brake clearance. that will help maximize the lip the you want/can get
it just depends on the specs and what faces you go with. which vsxx you going with? the reverse lip or step lip?
RavSpec
11-15-14 08:32 PM
HenryLee
Wheels, Tires & Brakes Forum
12-10-11 06:14 PM
