Cam timing control valve
Old 11-21-14, 03:00 PM
Ants350
Ants350's Avatar
Default Cam timing control valve
Hi so had code P0390 when I had my radiator changed had them check engine code they said sensor is going for cam timing control oil valve is starting to go. So my question is I want to do this myself looks easy is it plug and play?? Anything I have to do with timing the car or something? Please someone help here.
Old 11-21-14, 04:06 PM
Gville350
Gville350's Avatar
Which one? I believe there is one per cam. The shop could have broken a clip, pulled the harness out, or the thing could just be going out on you now. Look at all four and see if all of the harnesses are plugged in.
Old 11-21-14, 05:41 PM
Ants350
Ants350's Avatar
No one touched them. Lexus did diagnostic position 2 on drivers side right on top. There's 2 sensors on that side one for exhaust one for intake. They said do the bottom one first which is exhaust so I will do that. But first I will check all the plugs and maybe spray some electronics cleaner on the plugs clean em out see if code comes back. If it's the sensor is this an easy DIY?
Old 11-21-14, 08:01 PM
Gville350
Gville350's Avatar
Are these the same things as what are troubling your 2IS?
https://www.clublexus.com/forums/rx-...ement-diy.html
Old 11-22-14, 09:11 AM
Ants350
Ants350's Avatar
Are these the same things as what are troubling your 2IS? https://www.clublexus.com/forums/rx-...ement-diy.html
Yes! Thanks for that can't find anything on an IS..I will wait and see if code comes back I just cleaned up and tightened plugs up.
Old 11-22-14, 01:37 PM
Gville350
Gville350's Avatar
Cool. Let us know if the issue returns!
Old 11-22-14, 03:13 PM
Ants350
Ants350's Avatar
Yes I will thanks. Seems like since I hit 100k everything going on me! Wow.
Old 11-23-14, 12:01 PM
Gville350
Gville350's Avatar
^Don't tell me that, I'm nearing 85k now.
Old 11-23-14, 12:34 PM
Ants350
Ants350's Avatar
Sorry lol lets see if this P0390 code comes back Lexus tech said the solenoid on those sensors goes and comes back in cycles so right now code is gone when it's completely gone code won't clear. So if it does come back I will swap it out.
Old 11-23-14, 05:46 PM
jst17
jst17's Avatar
Keep us updated. My Acura used to throw that code. So the dealership changed the VVT cam shaft sensor, and the code went away. It only randomly pops up during really cold winter days. Some mechanics told me that the timing chain was slipping (tensioner was lose).
Anyways, good luck. Cant believe you've had so many problems with your IS. I was told by a certified lexus master tech specifically to NOT purchase the 2gen IS(250/350 a bit better he said). He said only the 1st gen are built to last.
I'm at 62k miles. The plan is to sell her before she hits 100k.
Old 11-24-14, 01:15 AM
Ants350
Ants350's Avatar
Yes I been having a bit of bad luck lately I'm pretty good with my maint. I don't play around when it comes to that. So far no code see what happens I'm counting on it to come back. :/
Old 12-05-14, 06:12 PM
Ants350
Ants350's Avatar
::update:: damm P0393 code came back. I just ordered cam gear timing valve. Gonna replace the one on the drivers side exhaust.
Old 12-05-14, 07:11 PM
jst17
jst17's Avatar
That did the trick for my acura. BTW did you do the cam gear VVT recall? Keep us updated.
Old 12-05-14, 07:50 PM
Gville350
Gville350's Avatar
Well, hope the new one does the trick for you.
Old 12-06-14, 01:16 AM
Ants350
Ants350's Avatar
Recall? Are you talking about cold rattle start? If so yea been had that done 2 years ago....yes I hope so thanks.
Drok149
IS F (2008-2014)
29
06-01-24 05:12 PM
ACKERIS250
Performance
02-10-18 07:05 AM
TTslim
08-27-15 04:02 AM
buckeycat
07-10-15 10:25 PM
MrMark
06-12-14 07:40 PM
Quick Reply: Cam timing control valve
