Did I install the steering wheel correctly? *Pic attached*
Old 11-22-14, 01:16 PM
smokyis350
smokyis350's Avatar
Default Did I install the steering wheel correctly? *Pic attached*
I took off the steering wheel to install a steering wheel leather wrap. But I'm not completely sure if I put it back properly since it feels a little bit looser. I can't recall if there was a gap.
Anyways, I also attached a picture of the finished product.
Attached Thumbnails Did I install the steering wheel correctly? *Pic attached*-img_0242.jpg   Did I install the steering wheel correctly? *Pic attached*-img_0240.jpg
Old 11-23-14, 07:58 AM
ivnnln
ivnnln's Avatar
I don't remember seeing this wide of a gap when I istalled the damped. However, I did not take it off completely. Hope the photos will help.
Attached Thumbnails Did I install the steering wheel correctly? *Pic attached*-image.jpg
Old 11-23-14, 11:28 AM
Gville350
Gville350's Avatar
That does appear to be a pretty good gap in there. I just took my feeler gauges and measured an approximate 5-5.5mm gap in between the steering cover and the wheel. My steering wheel has never been removed...yet.
Old 11-23-14, 11:37 AM
smokyis350
smokyis350's Avatar
Thanks for the help guys. Had to remove everything and re-adjust the steering wheel. Now it looks like the photo above.
Old 11-23-14, 11:42 AM
Gville350
Gville350's Avatar
Since I've got myself a new perforated leather F-sport wheel in the mail on its way to me, what DIY or thread did you use to help with your wheel removal/install? Any tips/tricks one should know before attempting this? Thanks!
Old 11-23-14, 11:48 AM
smokyis350
smokyis350's Avatar
I followed this video. Everything else is pretty much straight forward. Just make sure that the steering wheel is flush when you install it.
Additional info, you can see here:
https://www.clublexus.com/forums/is-...eel-cover.html
Old 11-23-14, 11:58 AM
Gville350
Gville350's Avatar
^Yep, pretty straight forward actually. Do I need to be that well-dressed in order to accomplish the job? LOL!
Old 11-23-14, 03:51 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Well you drive a slightly luxurious vehicle. But of course you do.
Old 11-23-14, 05:36 PM
Gville350
Gville350's Avatar
^I'll ensure the wear my nicest "beater" then!
Old 11-23-14, 07:49 PM
chi123
chi123's Avatar
smokyis350, you did a good job with the cover. I spent 3 hours stitching mine and it came out like crap with parts not sticking in place. Looked so bad, I just went ahead and bought a new wheel off eBay.
Gville, just follow Sewell's video. I watched it and got it done it under 20 minutes in freezing weather in my garage. Here's the result!
Old 11-24-14, 01:20 PM
smokyis350
smokyis350's Avatar
That steering wheel looks much sicker than mine. How much did you pay?
I think it is a 10 minute job to remove the steering wheel. First, disconnect the battery (10mm) socket. Then pop off the 2 covers on each side and loosen 2 T-30 torx screw on each side. Then get a flat head screw driver and pop out the air bag plugs. Use a 19mm socket to remove the steering wheel bolt. That's it.
Old 12-03-14, 09:00 AM
G4lexboi
G4lexboi's Avatar
One sweet interior
Old 12-03-14, 10:10 AM
07bsmtis25
07bsmtis25's Avatar
clean....
Old 08-25-16, 09:05 AM
aiexbadboy
aiexbadboy's Avatar
hi guys, just swapped steering wheel and i noticed the gap as well, what about airbag cover doesnt seem to sit flush or is it suppose to look like that? spend two hours and still cant figure out
side view
top view
Old 08-26-16, 11:42 AM
Deathrow23
Deathrow23's Avatar
yeah same here, i swapped mine to DCTMS steering wheel about 4 months ago i have that same gap.
i emailed them and they said send them a picture, but if others are having the same issue, it probably is just the steering wheel core that they use.
Quick Reply: Did I install the steering wheel correctly? *Pic attached*
