DIY Paint Chip Repair - Starfire Pearl (PICS)
Old 01-02-15, 06:02 PM
mdk77
mdk77's Avatar
Default DIY Paint Chip Repair - Starfire Pearl (PICS)
My hood had gotten a paint chip about the size of a pencil eraser. I believe this was done at the dealership as I never noticed it until I got it serviced but I have no way of proving this...anyyywaaayyys
I didn't want to spend the hundreds in insurance deductibles to repair this and I suspect it will happen again so I fixed this DYI - sort of.
Below are pictures of the before, during, and after. I am not done yet; I haven't put on the clear coat (077). I've only put on the base coat (077-BC).
My ask to anyone is whether I'll ever be able to get the hole filled to the same "depth" as the original paint. As you can see in the pictures, the original paint "lip" still shows. I've put on 3 thin layers of base coat already. I may try a fourth but not sure if the clear coat layers will add to that depth.
Also, an important note to anyone trying this; I put on a first and second layer of base coat. When I put on the third layer, I could hear the applicator pen crack through those layers. I pressed too hard. So I put on the third layer to compensate. It is tricky because to get paint to the tip, you must press hard enough on the applicator pen. I only used the brush once. For me the brush didn't evenly smooth everything so I didn't use the brush after the first coat.
Feedback welcomed!
Old 01-03-15, 08:09 AM
pmanliu
pmanliu's Avatar
If you want it to be almost as smooth as the OEM, you're going to have to overfill it, then sand it back down. Its going to be difficult just doing it layer by layer since you still need to take care of the edges.
Check out this DIY on youtube from AMMO NYC
Old 01-03-15, 12:00 PM
sl227
sl227's Avatar
what type of touch up paint did you use?
Old 01-16-15, 10:00 AM
mdk77
mdk77's Avatar
Thanks for the reply. I would not dare touch my car with any kind of sanding material - lol. I will leave that to the pros.
I used both the 77 and 77-base paint from Sewell. The color looks good it is just that there's a "dip" where the new paint is. I just needed to fill it in more. I am going to leave it until spring and have a body shop fix it right for me.
Old 01-16-15, 10:34 AM
scott1256c
scott1256c's Avatar
You would have to get it shipped to you fairly quickly, but you could try langka "blob eliminator". It will smooth off the top of the blob/excess paint and not ruin the paint below. You will likely have to smooth, then retouch and repeat a couple of times.
Once the paint has set long enough, the stuff won't work anymore, but you should have several days before that happens.
I have used it, it does work, and it is not as easy to do as the sellers would have you believe
Old 01-16-15, 11:41 AM
getafewliv
getafewliv's Avatar
For my paint chips, I used Dr. Color Chip, I find it works quite well and is super easy to use. I definitely prefer it over paint pens.
Old 01-22-15, 06:38 PM
mdk77
mdk77's Avatar
Do you think if I take it to a reputable body shop they can fix this without painting the whole thing? Perhaps they can fill in the hole, wet sand, wash, wax...?
Old 01-22-15, 06:56 PM
VTsuckah
VTsuckah's Avatar
They can easily fill it in and make it smooth, but you likely will be able to see where the work was done up close.
Old 01-23-15, 12:59 AM
AiRuss
AiRuss's Avatar
I also have a chip in my starfire pearl hood. I am going to try Dr. Colorchip. Keep ya posted.
Old 01-23-15, 08:27 AM
getafewliv
getafewliv's Avatar
I spent a sunny day going over my car completely and filling every little rock chip multiple times over (trying to make it flush with the paint). Made a big difference when I was done. I would never go back to a paint pen.
Old 01-23-15, 12:11 PM
FSportIS
FSportIS's Avatar
+1 on Dr.Colorchip. Done it right, it is close to professional touch up. It is super good to fix rock chips. However, hairline scratches (like the one in the video) is super hard to correct regardless what method.
Old 01-23-15, 01:13 PM
tklovett63
tklovett63's Avatar
Hope the Dr. Colorchip works...may try it too
Old 02-22-15, 12:57 PM
Lexusboy4
Lexusboy4's Avatar
It looks good man, you're brave though, I'd never have the guts to do that myself
SLH
ES - 6th Gen (2013-2018)
09-15-14 05:12 AM
raj824
07-12-10 12:17 PM
handzilla
07-07-06 09:26 AM
Quick Reply: DIY Paint Chip Repair - Starfire Pearl (PICS)
