Does everyone's car get stuck like this?
Hey Everyone,
I recently purchased a RWD Lexus IS350 07. I installed bridgestone blizzak tires, which set me back close to 2k. I was aware of the difficulty of driving in snow with RWD cars, but it seems that whenever there is approximately 2cm-4cm of snow my car get stuck. In approximately 2-3cm of snow (By my bet gusss) just yesterday, it took four people rocking my car back and forth to get me out of the mess.
And it's happened multiple times.
I've heard that putting sandbags in the back trunk could help, but aside from that is this a normal experience I'm having? I'm hearing some odd noises in the back tires right now, so I'll have to get that checked out but it's absurd getting stuck in such little snow.
Could anyone comment of their state of getting in and out of snow?
Thanks.
Thanks.
You need to drive with traction control off. Other wise if your car feel slippage it will cut power therefore you can't move. I've driving 5yrs threw storm , blizard and ice with no issues. I don't use snow mode and I don't sandbag my trunk either. Learning to drive it is a plus. Once you get use to it you'll be fine.
Just went out to the garage to make sure, but my '06 350 has a switch on the dash for Snow. It is a rocker switch to the right of the steering wheel. Top position is PWR, middle is ECT and toggled down says SNOW. Living in SoCal I've never put it into the SNOW position to know what it does though.
Take it cause your not confident in your driving. But what did people do 100yrs ago when there was no awd? I be leave they did fine. Cause the OP just got his first RWD doesn't mean the car sucks. Another fact it doesn't snow everyday during winter season and street get plowed clean same day.
I drove my RWD IS250 last winter in Ontario with Blizzak WS70 on OEM 18s. I had no issues even during the snow storm. Which part of Ontario do you live in?
Snow mode helped me with traction when the highways were not yet shove but otherwise no issues at all.
And the thing is, I hear the engine rev, it's not cutting the power (at least when im stuck in snow), but the car isn't going anywhere. I tried the whole reverse, move forward in different directions which didn't work, shoveling underneath the back tires, etc etc and for some reason it still didn't work.
Just a note, driving around regularly isn't much of an issue for me (i.e. skidding too hard, losing control, etc doesn't happen all too often for me). What had happened was there was approximately 2cm in snow that I had to park into (i.e. my parking spot), and I didn't think it would be too difficult to pull out of it, but in the morning (it hadn't snowed overnight), it was incredibly difficult to get out (and required pushing).
Thanks everyone for the detailed responses, it is much appreciated!
I have an AWD with snow tires and I must say a lot of people were jealous and upset to see me going up hills around SUV's and trucks that get stuck.
when it comes to 2WD cars, its sometimes best to have weight on or near the drive axles of the cars so if not something heavy then put people in your back seat. One thing Ive learned is to never floor it out of snow or ice because that makes it worse. Gentle taps of the pedals goes a long way. Also in heavy snow storms, I ALWAYS drive in S mode with paddle shifters. Reason why is because sometimes you cant always slow down or stop the car as quickly so the gear limiters make it easy to use engine braking or slow down the wheels of the car
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/image_2607acad4a8848fa4bff38cfb0006f74cbbcfcdf.jpg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/image_357a0612232fd184d35cc122582e04c62adfd249.jpg)
If I can get out of this with out an shovel and simple gunning it forward you don't know how to drive the car yet. I hold the traction control till both traction and vsc are off. From stop and go time you wanna feather your gas pedal. Other wise you might go side ways with no traction.
Hey Everyone,
Thanks.
Thanks.
Proof of you getting stuck in snow would help! Pics or it didn't happen.
IS350.. 18" snows.. car is actually pretty decent in snow so far for what we've gotten, but then again I intentionally go out to play in snow and have a good understanding of vehicles
