LEDs inside flicker when dimming on and off?
Old 01-22-15 | 05:05 PM
tomiv9's Avatar
tomiv9
Default LEDs inside flicker when dimming on and off?
I just replaced my dome lights in front and back of cabin with Blue LEDs. They all sort of flicker a bit when they dim on and off. Is this normal?
Old 01-22-15 | 06:23 PM
gurble's Avatar
gurble
Yes, this is normal for LED's.
Old 01-23-15 | 11:22 AM
TophersToy's Avatar
TophersToy
Yes. Dimming is mimicked by turning the bulb on and off repeatedly. This works for a halogen bulb as it takes awhile for the bulb to charge up. This is almost instant for led which is why you actually see each on/off sequence.
Old 01-23-15 | 12:53 PM
Gville350's Avatar
Gville350
Yep, happens with mine as well.
Old 01-23-15 | 01:34 PM
getafewliv's Avatar
getafewliv
Standard filament style bulbs vary the light output based on the voltage being applied to them.
LEDs on the other hand require a certain voltage before they turn on and operate properly. Without sufficient voltage they tend to flicker.
In order to create a nice dimming effect your car will increase the voltage up to 12V over a few seconds. This works for the incandescent bulbs but not the LEDs.
satz
12-24-12 07:08 AM
xspsi6
Lighting
04-26-12 08:39 AM
RC51TOFUMA
01-19-10 02:25 PM
thirdmotio
Lighting
22
07-28-05 10:29 PM
///MDex
02-21-02 06:46 PM
