washer fluid warning light
Old 11-14-19, 06:12 AM
2013FSport
2013FSport's Avatar
Received 1,533 Likes on 1,276 Posts
Thumbs down
Originally Posted by Gville350
BTW, anyone else ever get freaked the hell out when that error message comes up thinking it was something which worse? LOL!
Car was 3 mo new to me mid summer 2017, I hit a 270° ramp *playing at speed* and the dam thing came on which freaked me a bit like it oil starved or something! Then as I read it, all I could think was "them A-holes that designed this thing could have put a delay on there...." lol or maybe:
While: G-Force >0.1 Do Suppress_Washer_Low_Fluid_Warner_Lamp
End While:
Sort of like the low fuel gauge latches on once detected, as it never toggles on/off it just latches on until refilled.
If I remember right, if you loosen up the front driver's side wheel liner enough to gain access behind it, you should be able to access it. Going straight off of my memory though...could be wrong. Otherwise, you'll need to remove the engine under panel and gain access from underneath the front end.
I tried to install LED turn indicators and had the lower engine cover off. It's a lot of screws but offers the the best access to the washer tank.
If I read this thread right, there is no float just some exposed conductors sending current through the fluid. If coolant is low, no current flows and light is triggered. That said OP is looking for a bad connection. When you find the connector; jumper a 1M ohm resistor across it. If the light remains on, the problem is upstream somewhere.
FWIW - that same tank prevents one from installing LED bulbs in the 2011 up cars as its smack dab in the way.
javohio
07-10-15 09:15 PM
dkingphd
01-06-08 04:01 PM
Bichon
02-27-07 08:39 PM
Macgyver
11-18-06 08:15 AM
Quick Reply: washer fluid warning light
