car won't unlock driver side door with kay fob
Hey guys I'm new with a 2nd Gen
Just bought a 250 07' and car won't unlock the driver side door not even hitting many times the unlock button. Any help what could be causing this
Thank you in advance
Sounds like the door lock actuator is pooping out. You could also DIY and replace it if you are comfortable doing it. I replaced my back two door lock actuators. There's two ways of doing it. Buy a used door lock actuator or just buy the motor. I butchered my door lock actuator trying to take it apart so I just found a used actuator on eBay for like $75 each. Just gotta pop off the door panel and remove the cables. Roll your window up so you can get your hand behind the door. Remove the 3 torx bits (t40 I think) and pull out the old actuator. Put the new one in and reverse order and you are good to go.
That's the issue it doesn't work. When I get closer to the car even putting my hand thru the handle doesn't unlock.... I was wondering if it's mess up or just needed reprogramming
