IS350 Timing Cover Repair
My dealership also had been noting a leak from the timing chain cover for a couple oil changes. They quoted me 18 hours of labor - $3,500 to remove the engine, repair the leak, then put the engine back in.
I know a good mechanic so called him to get a second opinion. Dropped the car off, and within a few hours he called and said it didn't appear it was the timing chain cover at all, but a metal plate above it that was leaking down. It made it appear that the timing chain cover was leaking. Opposed to the timing chain cover which would require the engine to be removed, he could reach this smaller cover. He advised that we clean it up, apply some sealant to the smaller cover, and tighten it to spec. He'd then check it in a week.
Two weeks go by, I take it in for a check, and it's dry and clean. Total bill - $85.
I'm attaching a couple pictures that show what it is I'm talking about. I asked him to take them in case I needed to pursue the issue with my used-car warranty company. So - get a second opinion.
caramoe (09-28-21)
^I wonder if that is some sort of inspection cover plate. Anyhow, glad yours was a simple fix! However, there have been documented timing cover leaks, so it wouldn't be far-fetched. But definitely a good idea to get another opinion!
caramoe (09-28-21)
That's the timing chain tensioner inspection cover. I'm willing to bet that wasn't your leak. The timing cover leaks at a gap in FIPG on the cover where the head and block meet. I'm not certain of late model 2nd gens. But the early ones will all leak eventually. Sorry to be the bearer of bad news
caramoe (09-28-21)
caramoe (09-28-21)
Yes.
Oh absolutely. Its a shame the Achilles heel of the 350 in my eyes, is the $2000+ repair everyone needs to make because of a simple oil leak. If its just your inspection cover 👍👍 that would be a blessing
caramoe (09-28-21)
Here's my oil leak between the timing cover and engine block. Is this the infamous oil leak everyone has?
There was also an oil leak at the oil cooling pipe bolt but I have already fixed that by replacing the washer. Not sure if it occurred when the dealer did the recalls or when they repaired the timing cover (yes the previous owner of this car had the timing cover repaired before by the dealership, but it was a few years ago so no goodwill or any warranty/coverage )
caramoe (09-28-21)
5K miles later my oil has dropped from full to just about half way. Can anyone confirm the parts I will need for this repair?
As per TSIB EG001-07 GR-FSE Series.pdf:
11103–31011 Housing Sub–assembly, Camshaft, RH
11104–31031 Housing Sub–assembly, Camshaft, LH
90105–06323 Bolt Flange (qty: 17)
90105–08456 Bolt Flange (qty: 4)
90119–06980* Bolt, w/Washer (for Fuel Pipe No. 1) (qty: 2)
04111–31600 Gasket Kit, Engine Overhaul
Three Bond 1324 or Equivalent As Needed
FIPG Sealant: P/N 08826–00080 or Equivalent As Needed
I also found this post from Jeff Lange here:
Looks like the parts Jeff listed replaces the Gasket Kit in the TSB.
I only need 00295-00103 FIPG sealant right?
Since I was feeling like looking into this further, these are the USA MSRP prices:
$25.38 - 11213-31040 - Gasket, RH Valve Cover
$13.96 - 11214-31020 - Gasket, LH Valve Cover
$7.92 - 11159-0P010 - Gasket, VVT-i Oil Feed (Qty: 4)
$2.82 - 90430-A0001 - Gasket, VVT-i Oil Feed (Qty: 2)
$10.75 - 11328-31030 - Gasket, Timing Cover Inspection Hole
$14.85 - 90311-42045 - Seal, Front Crankshaft
$3.65 - 15147-0P020 - Gasket, Oil Pump (Timing Cover to Block)
$2.99 - 15193-0P010 - Gasket, Oil Pickup (Timing Cover to Pickup)
$5.88 - 90430-16012 - Gasket, External VVT-i Oil Pipe (Qty: 4)
$2.82 - 90430-16016 - Gasket, External VVT-i Oil Pipe (Qty: 2)
$10.96 - 17176-31060 - Gasket, Intake Plenum
$27.99 - 16271-31020 - Gasket, Water Pump
$4.08 - 96761-35025 - Gasket, Front Water Housing to Bypass Pipe
$1.58 - 16325-31010 - Gasket, Front Water Housing to Block
$5.25 - 04152-YZZA3 - Filter, Engine Oil
$1.13 - 90430-12031 - Gasket, Oil Pan Drain Plug
$13.82 - 00295-00103 - FIPG / Sealant
Engine oil and coolant as needed.
$155.83 - SUB-TOTAL (Parts)
Labour (Warranty Time): 12.3 hours
Labour (Standard Time): 24.0 hours
If they're charging the non-warranty labour time, I can actually see it getting close to $3000. I am quite surprised to see the non-warranty labour time as that much more. I mean it's usually more, but an extra 12 hours? Quite significant. I can also see why they would use that time, haha. No tech is going to quote the warranty time, lol.
I would maybe call around and see if anyone will do the job for cheaper. Obviously labour is the big number here, so if you can find someone who will do it for less, you will save big.
Jeff
Jeff
saleen90
01-06-14 08:39 AM
