is300 2011
Old 03-05-15, 08:07 AM
b4u2015
b4u2015's Avatar
Default is300 2011
Good day
I am having is300 model 2011 ( gulf specs) 3.0 liter engine
I am planning upgrade my stock wheels to get avant grade m310 19 inch wheels
Rear: 245/45 R17
Front:225/45 R17
I would be more than happy guide me on how to do it without problems
-Should i first change suspension?
-Should i lower the car and does cause problems like noise or i hit a bump or anything else will damage the car as i am a normal driver looking to change the look only
-How to chose the tire that will suit my car?
Thank you
Old 03-05-15, 02:43 PM
LP817
LP817's Avatar
You should get tires for 19inch wheels (ex. 245/45/r19) instead of r17.
As for suspension Id just get new lowering springs to eliminate the wheel gap when you put on the new wheels. You would have to be a little more careful on larger bumps. Nothing should get damaged as long as youre careful. And if the springs get installed properly and nuts get torqued down to specs. Then youll be fine.
Old 03-05-15, 06:37 PM
lysis250
lysis250's Avatar
Do suspension first, I did wheels before my suspension and I was embarrassed to drive my car looking very awkward. For best tire size we need to see the specs of the rims.
Old 03-05-15, 08:05 PM
Initial G
Initial G's Avatar
I would also suggest working on your suspension first before purchasing new wheels.
If you want the ability to adjust your ride height, you should consider coil overs instead of springs.
Congrats on the new car and good luck with the mods!
Old 03-05-15, 11:15 PM
b4u2015
b4u2015's Avatar
Thank you guys
I am planning to get this
http://www.elementwheels.com/proddetail.asp?prod=ava-3101985grava-3101995gr
(2) 19x8.5 Avant Garde M310 Dolphin Gray
(2) 19x9.5 Avant Garde M310 Dolphin Gray
Your opinion guys on the grey wheels with black color car??
Also which suspention brand should go for as i mentioned before i am looking for comfort drive not for performance ?? Any tips
Old 03-05-15, 11:49 PM
SGMISF
SGMISF's Avatar
Have you looked into Avant Garde M590? I prefer those over m310.
But yes suspension always comes before wheels. If your budget is small, consider megan ez coilovers. Some other popular brands that are not too expensive are BC Racing, Megans, etc. Check out the vendor market section, I'm sure you'll find what you're looking for there.
Old 03-06-15, 02:03 AM
b4u2015
b4u2015's Avatar
Oh maaaan i am not sure about all those mods
hmmm ok how about getting 18inch wheels i think they will fit without lowering the car and change suspention??? Any idea guys or any opinion in this regard
Old 03-06-15, 04:28 PM
SGMISF
SGMISF's Avatar
Regardless how what size wheels you go with it's going to look strange getting aftermarket wheels without lowering your car. If you're on a budget I would suggest lowering your car first and waiting for aftermarket wheels.
Old 03-09-15, 01:28 PM
b4u2015
b4u2015's Avatar
Thank you guys
soo basicly putting lower springs will do the job...any suggestions (brands)
Old 03-11-15, 01:39 AM
b4u2015
b4u2015's Avatar
http://i1069.photobucket.com/albums/u475/ebayman2001/Snapbucket/3DD51A51_zps5324cb98.jpg
I want this look...this guy he put on 18inch AG dolpin grey and i dont think he lower the car??
Any idea??
Tom2769
IS F (2008-2014)
09-16-16 10:25 AM
mmartin061
IS F (2008-2014)
12
06-25-16 12:24 PM
aristott
GX - 2nd Gen (2010-2023)
11-21-10 07:46 AM
Silver88
IS F (2008-2014)
09-24-10 12:44 PM
Quick Reply: is300 2011
