Need help with wheel fitment
Old 03-11-15, 08:39 AM
jbone29
jbone29's Avatar
Default Need help with wheel fitment
Will a 19x9.5 and +20 offset in rear work? I do not want to rub or anything. I plan on using 255/35/19 tires in the rear.
Old 03-11-15, 11:25 AM
dannyboy26
dannyboy26's Avatar
You will rub a lot unless you roll, pull fenders and even shave down the tab that connects fender with bumper... And you will also need upper control arms from either spc or megan racing... i did all the above with a 19x10.5 +22 wheel and running -4.7 camber. How low are you wanting to go?
Old 03-11-15, 11:51 AM
jbone29
jbone29's Avatar
I am not wanting to lower at all just wondering if i will rub with that offset. I have read where some people have a 9.5" wide wheel and do not rub or anything. Will that offset stick out to far? If i have to do any mods i will just get the +35 offset.
Old 03-11-15, 02:26 PM
kumquatism
kumquatism's Avatar
9.5" +20 in the rear will most likely need a roll. +35 would be a better offset if you're absolutely against any fender mods
Old 03-11-15, 03:31 PM
jbone29
jbone29's Avatar
Correction...rear wheels are 19x8.5 with+20 offset. That should be about the same as 9.5 with higher offset right?
Old 03-13-15, 08:22 AM
dannyboy26
dannyboy26's Avatar
If you are not lowering they will stick out like crazy not sur how it'll look but ten again they are only 8.5 wide so may look decent without lower and some beefy tires
kwags1023
03-18-12 01:35 AM
boxcarfan
GS - 1st Gen (1993-1997)
14
11-02-09 03:16 PM
Socal300sd
Wheels, Tires & Brakes Forum
07-20-09 04:38 PM
The Law
07-19-06 09:38 PM
indypwr
07-13-06 03:13 PM
Quick Reply: Need help with wheel fitment
