Is hidden menu nav
Is hidden menu nav
So I found the hidden menus in my nav on my is250 but now I want to know what they do if anyone gots a pdf or knows an exact thread to what they do that would be great!
we use these menus at our toyota dealership for certain diagnostics to figure out if the nav unit is failing or if certain input items are failing. thats all I've ever used it for anyways
I've honestly just used to so far to check signals such as blotch and xm input. i can poke around in the diagnosis area of our TIS program when i get the chance and see if i can't find any more in depth detail on this stuff
2006, 2007, 2008 do not have the nav override.
that show pulses #
mph
kph
what are the pluses for?
I found a few of them, that are not obvious, interesting. such as the speed and pulses
-press and hold info
-flick parking lights on and off while still holding info for about 4-5 clicks
-you get to one of these...
-to go even further click menu at the top right corner
-click than top left and bottom right
-you go to another menu.
-when done hold display on nav unit until it resets.
cheers
And on top of that I go to menu, volume , top left bottom left, top left bottom left, and it does not work on my unit. My unit is not the stock 2006 unit I had to replace mine with the ML unit but im sure its a 2007.
is there an alternative way of overriding the nav?
