I hate cigarette lighters
Hello Group. I have just recently became the owner of a 2006 Lexus IS 250. I love it. I bought it from a guy about a month ago. He put a new transmission in it because the old one went bad but the car runs like a charm. It really gets up to speed. But anyway. When I got the car none of the cigarette lights were working. So I did some research and I found out that I should try changing the fuse in the front passenger kick panel. So I changed the fuse. It was a 15 AMP. The front cigarette lighter was working but the middle console cigarette lighter was not working. Now all of a sudden the front cigarette lighter is not working again! Im not sure what this is. Does anyone have any other options for me. I really need a cigarette lighter as I have a smart phone and as you all may know smart phones go dead pretty fast and I travel a lot. I was thinking about taking the car to the dealership for this but I think that would be kind of a rip off. Thanks guys.
"when I got the car none of the cigarette lighters were working"
I'm guessing the prior owner was having issues and finally gave up on continuously changing the fuses, have someone who knows what they are doing check the circuit out or install a new power point in your favorite accessible spot
fuses don't blow for any reason, something seems
unless you are the OP or sold him the car this message was not intended for you. The OP stated that the outlet did not work and once he found the fuse and changed it, it burnt the fuse out again, I was giving him advice on his particular set of circumstances on his car
Sorry but it was hard to understand your descriptions of the issue. I have some basic questions:
1. Were both of the outlets (cigarette lighter) have power after you replaced the fuse? You might need a volt meter to check.
2. Or the fuse blew as soon as you plugged in the charger?
I am suspecting you might have issues with the wires shorting out; which is hard to find unless you tear everything apart to trace the harness. If you are handy, one option would be re-wired the outlets and tap onto a spare slot on the fuse panel.
I also have this issue, The front ashtray outlet works but the one inside the console does not. Are they on different fuses?
Also, I seem to get a some feedback (static noise) through my speakers when my phone is charging through the front outlet when using the AUX cord.
Acer
08-13-17 02:34 PM
gmo7979
12-16-13 11:21 AM
