Broken Wheel Studs
Old 03-28-15, 08:56 PM
hirsch2is
hirsch2is's Avatar
oh and btw I've never EVER had a stud break on my own car, family members car, or customers car. just sayin
Old 03-28-15, 10:59 PM
scorpionge
scorpionge's Avatar
proper torque is 76ft/lbs sounds about right... thanks to a over-torqued previous owner i had some bald nuts on my g37's shocks.. yeah.. bald nuts lol
Old 03-30-15, 02:12 PM
Gville350
Gville350's Avatar
^Hey, this is a family-friendly forum; keep the comments about your hairless nuts to yourself.
Old 04-06-15, 11:27 PM
kwanye
kwanye's Avatar
UPDATE: I just replaced all 10 of the rear lugnuts and torqued the lugs with a torque wrench to 76. Retorqued after I drove some too. Hopefully the studs don't break again.
Old 04-07-15, 07:56 AM
scott1256c
scott1256c's Avatar
Let us know if one breaks.
How did 76 "feel" on a torque wrench compared to what you were doing before?
I know it is likely to be hard to tell.
Old 04-07-15, 10:48 AM
kwanye
kwanye's Avatar
It felt a lot less tight compared to what I was doing by "feel". I've been checking them after I get back home at the end of the day. One stud was looser than the others but not by much. They are holding up pretty good now, hope it solves my problem.
Old 04-07-15, 12:30 PM
Gville350
Gville350's Avatar
Alot less tight is good, because actually 76ft lbs isn't much...especially with a breaker bar. You should be good now; but do report back if anything goes wrong.
Old 05-25-15, 03:00 PM
kwanye
kwanye's Avatar
UPDATE: Even after torquing the lugs to OEM spec, the studs would still break. Looked at the hubcentric ring and they were kind of chewed up. Guessing that the sizing on the ring was off by a mm or two. Put new rings on and so far so good.
thanks for the help Gville350
Old 05-25-15, 09:46 PM
MikeFoxx
MikeFoxx's Avatar
The hub rings were the first thing that came to mind but honestly for $5 a set I didn't think that would have been overlooked. Glad you narrowed it down ... nothing worst than having to keep going back and forth with fixing studs.
Old 05-29-15, 02:01 AM
srt1
srt1's Avatar
Lol I can't believe I over looked that. I remember, back in the days, when I had wire wheels and I needed a center plastic ring that fits over the hub centric. Without that being centered properly your Wheel wouldn't be centered correctly. Glad it was a simple solution even though it took some time to figure it out.
sectorz33
IS F (2008-2014)
18
11-20-16 12:37 AM
R32S
ES - 6th Gen (2013-2018)
12-24-15 06:42 AM
Brokenis
11-19-15 10:34 PM
AAHawaii07
IS - 1st Gen (2001-2005)
01-12-11 05:46 AM
imports4me
04-08-10 10:24 AM
Quick Reply: Broken Wheel Studs
