Side mirror glass
Looking to replace my drivers side mirror glass as mine cracked. I figured since I was needing one anyway I might as well go with a tinted blue glass or something similar. Has anyone else done this or know the best place to get the replacement glass?
my rear view mirror was shaking as well. It was loose at the ball joint just behind the mirror itself, not at the bracket mount on the windshield. I took the front trim off the mirror, let the mirror hang down a bit and there's a screw that holds the ball joint to the mirror case. I found it tight, but as I was trying to unscrew it it move about 1/8th a turn. That tightened it up completely. Now my mirror does not vibrate at all.
