2006 Lexus IS350
Hi turned my car on today and my engine light, check vsc and traction control light came on. Connected it to a computer and the codes where p0606 ( processor failure )and p0138 (o2 sensor high voltage bank 1 sensor 2). Wondering is the p0606 major or is it failing because of the o2sensor. Also wondering why the traction light is on aswell?
Super Moderator
When the CEL comes on (for any reason), the computer disables the stability and traction control. That's what causes the Check VSC indication.
When the CEL light comes on with the traction control light, it usually means it has something to do with emissions.
It could be a loose gas cap, or a bad sensor (MAF, 02 sensor, etc.)
From my experience it was always a loose gas cap.
All of this is normal.
& once you change your o2sensor(Bank 1 Sensor 2 Oxygen Sensor) & reset all the codes that your problem will be solved.
what ever you do DO NOT take your car to Lexus Dealership & do this task all by yourself cause it's way too easy to save $600 + inside your own pocket.
Good Luck
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Good evening fellow Lexus member,
Good Luck
Good Luck
