Strange issues leaving me baffled
Old 03-30-15, 09:29 PM
takadakeyo
takadakeyo's Avatar
Default Strange issues leaving me baffled
Greetings
So few nights ago something strange happened. I was driving and my radio started to flicker and then shut off. Thinking it's a fuse I kept driving and suddenly all my warning lights lit up and started to flicker and my car shut off.
When trying to start it everything just flashed and shut off. Didn't crank or anything. Even my hazard lights would work. I press it again and everything lights up but no crank. Press it again and my hazards turns off.
I just had battery replaced and when replacing they said my starter and alternator was fine.
Anyone have a similar problem or know what's wrong? Should I test alternator again? This is on an 06 is250 rwd
Old 03-30-15, 09:53 PM
liqB
liqB's Avatar
It sounds like the alt isn't charging the battery. Before you replaced the battery, was the old one completely dead?
Old 03-30-15, 11:39 PM
Toyboy250
Toyboy250's Avatar
Originally Posted by takadakeyo
Greetings
Sounds similar to an issue i had, read this: https://www.clublexus.com/forums/is-...r-problem.html
Old 03-31-15, 01:14 PM
LucianoLee
LucianoLee's Avatar
It's either battery or alternator. Check the battery again first
Old 03-31-15, 01:22 PM
Gville350
Gville350's Avatar
Since the lights and such will work, but the car won't start, sounds like the alternator is toast. There's enough juice to power the low-draw lights, but not to start the car. This is starting to happen more and more here lately! Happened to be last year actually, with VERY similar symptoms.
Old 03-31-15, 01:33 PM
Zynthe
Zynthe's Avatar
This happened to me a last month. Could either be a blown fuse in the fuse box, dead batt (not likely as you replaced), or dead alternator.
Old 08-09-16, 08:33 AM
lextout
lextout's Avatar
Regarding spark,air and fuel, if I were to change parts on this car I would install the original ones on there.
Old 08-10-16, 05:02 AM
sam12345
sam12345's Avatar
First check battery cable battery connection ground fuses if all good battery or alternator or both
Old 08-10-16, 09:06 AM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Since this thread is well over a year old, I hope the OP has solved his problem
Lou
magnificen
13
01-10-17 10:28 AM
Sanddwich
Performance & Maintenance
12-03-14 01:46 AM
URDONE
02-17-11 08:13 AM
2.5tsoarer
06-01-08 02:22 PM
Quick Reply: Strange issues leaving me baffled
