Wiper Arm Identification
Hello all I recently purchased the entire blade for the passenger side wiper and while my box and pick list has the right part number it isn't fiting the curvature of the windshield right.
The identification on the arm states LG2 1461 NO1S27HA
Can anyone verify if this is what there arm states Under the part that the actual metal part goes too.
Sorry for the horrible grammer and what not I'm in the parking lot on my phone.I'll edit later.
Ok, I am available to add more information to this post.
I ordered the wiper blade from LPartsWorld to fit the 2006 IS350. While I double checked the part number on the box and on the order slip, the blade will NOT fit onto the windshield. The curvature of the arm is not matching the windshield for the passenger side. The driver side works perfect.
So during my trouble shooting, I decided to compare the drivers window side and the passengers side. I noticed one identification that stood out enormously and that is the drivers window had an identification of LD3 while the passenger side stated LG2.
I am wondering if this difference is correct, or if there is something that I am missing on my car. I am thinking it is possible that while the box has the right part number that the actual part is for something like a GS350 .
If anyone could take a look at their OEM windshield wiper blades and provide me that identification code, that would be great!
Thanks!
Thanks!
This is very old post but worth noting that many cars use the same OEM factory wipers as Lexus. I've seen them used on GM and Chrysler cars. Exact same wiper.
I'm looking at mine and one says LG2, 6840 N08U28YE, Other one says LD4, 1881 N08U07H1.
I think these are numbers related to the Denso OEM manufacturer who makes these for the car MFGs. You can cross reference the P/N with
Denso 160-3120 (passenger) and 160-3122 (driver).
Can be had for $35 to $40 from Rock Auto or Amazon.
https://www.amazon.com/dp/B002Y37K0Y
https://www.amazon.com/dp/B002Y37K4U
The 2IS uses, 500mm and 550mm (the 500mm is very common and I've seen on many cars, my Sienna uses that for passenger). The 550mm is not common and I hardly see it used on other cars.
The reason I stick to OEM is that the rubber refills are only like $4 or $5 so I've used them since car was new.
I also keep the blade body well protected with 303 Aerospace protectant and now ceramic coat.
