Removing plasti dip, is thinner safe for the rim?
Old 04-24-15, 06:29 PM
Jeffrimerm
Jeffrimerm's Avatar
Default Removing plasti dip, is thinner safe for the rim?
Now that I swapped out the loud exhaust for stock I'm gonna take the plasti dip off the rims. The previous owner did a thin coat. I saw a ton of ways to take off the dip with all kinds of liquids. I have wd-40 which needs to soak in for 30 min then scrub off. I also have some paint thinner which seems to work super fast. I don't want it to eat off the clear coat on the rims. I wipe away quickly but does anyone know if I should stay away from the thinner? Thanks
Old 04-24-15, 09:58 PM
MikeFoxx
MikeFoxx's Avatar
Roll the edges with your fingers and pull it off... that's one of their selling points.
Old 04-24-15, 10:32 PM
xhackr
xhackr's Avatar
No chemical that will remove this will not also affect the clear-coat. Follow Mike's advice and do it mechanically.
Old 04-24-15, 11:00 PM
scott1256c
scott1256c's Avatar
I used mineral spirits to remove the bits that I couldn't peel off. It worked just fine and did not damage the rim.
Old 04-24-15, 11:07 PM
Jeffrimerm
Jeffrimerm's Avatar
Thanks, I'll use that for rims 3 and 4. I think lots don't realize when people do cra$$y job it doesn't roll off with the fingers. It was so thin and dry I had to use a fuel line as a finger and push fairly hard on the first rim. Second rim was much better but still kinda thin. If I had goo-gone or black magic tire stuff I saw those work great too. WD40 would have been ok to to not harm the rims.
Old 04-25-15, 01:38 AM
RUCKER
RUCKER's Avatar
A micro fiber towel always worked well for me when I couldn't get the thin pieces to pull up by hand. Just rub the towel back n forth over the spots still stuck and it should rub away without too much hassle.
Old 04-25-15, 04:38 AM
MikeFoxx
MikeFoxx's Avatar
OP - you are right when it's too thin it's harder to get it off... ^^^^ this method works. I had to do this on my beach cruiser to get to of the pieces behind the crank.
Old 04-25-15, 06:46 AM
Kvs_350
Kvs_350's Avatar
Or there is a dip removal spray just spray it on and hose it off
Old 04-25-15, 07:38 AM
Sceanzo
Sceanzo's Avatar
The dip removal spray is basically goo gone. It works but I don't know how it will affect unprotected metal. I've dipped many Cars. microfiber and pressure washer work the best. Dip removal works very well too. But like I said I don't know the outcome on noncoated metal
Old 04-25-15, 10:06 AM
Ants350
Ants350's Avatar
Micro fiber cloth work rubbing back and forth.++ what I did.
Old 04-25-15, 04:19 PM
Kvs_350
Kvs_350's Avatar
I removed my dip from polished lip before and it doesn't do any damage to the wheels or clear coated surface
Old 04-25-15, 05:21 PM
meine96ws6
meine96ws6's Avatar
Thin layers are harder to remove. Soak in wd40 and scrub it off.
Old 04-26-15, 05:15 AM
SeanO
SeanO's Avatar
Had the same problem when I tried to remove the dip from my tail lights.. When applied it goes on thick( based on how many coats obvi) but over time the plasti dip wears away in the elements and becomes thin and very hard to work with.. To be honest I just used my fingers and struggled through it. If I was to recommend anything it would be a little bit of heat from a blow dryer.. Softens it up just a bit for ya
Old 04-26-15, 03:58 PM
jgoorn
jgoorn's Avatar
That sounds like a horrid idea! Glad you were removing it.
Old 04-27-15, 09:50 AM
vicsis250
vicsis250's Avatar
Goo gone gel works great get at Home Depot for like 5 bucks
Quick Reply: Removing plasti dip, is thinner safe for the rim?
