Knock Sound at Low RPMS
Old 05-05-15, 02:52 PM
PhiGam27
PhiGam27's Avatar
Default Knock Sound at Low RPMS
I have been noticing lately that when I start moving in first gear, if I let the clutch out at a normal speed, without giving the gas a little tap to raise the rpms, there is a knocking sound coming from the engine. Just one knock and I do not hear it again. Any ideas as to what could be causing this? Again, it is only if I am lower in my rpms from a stop. If i give it a little gas before letting out the clutch it does not do it.
Old 05-05-15, 03:54 PM
Gville350
Gville350's Avatar
How many miles on the clutch?
Old 05-05-15, 06:54 PM
PhiGam27
PhiGam27's Avatar
I should have mentioned. A little over 72,000 on the engine and less than 2000 on the clutch. Noticed the noise before the new clutch but assumed it part of the clutch issue when I got that replaced.
Ozzzzy
Performance & Maintenance
03-21-15 06:24 PM
Tabaka
04-26-13 06:19 AM
Recluse
06-15-07 05:07 PM
Camshaft
SC- 1st Gen (1992-2000)
06-10-02 06:55 PM
Quick Reply: Knock Sound at Low RPMS
