Aftermarket LED Projector headlight adjustment *help
Hi all! I'm sorry if this has been posted before but I couldn't find anything really. Does anyone have these projectors and would you know how to adjust the verticle setting on it? It currently points too high. I bought the car with them already installed. I found the screw where to adjust the horizontal setting (screw on top right).
Here are some pictures:
https://docs.google.com/file/d/0B5Sw...p=docslist_api
Any help is appreciated. And sorry for advance if this post is not posted correctly or not in the right area of the forum.
These are the first version of the replicas! Looks like someone already adjusted the driver side. I'd recommend turning the lights on while on a flat road, facing a wall, and then adjust the screw with teeth marks as you started.
For some reason I thought there's supposed to be 2 screws, one for left and right and the other for up and down.
Let me know how it goes, or someone else can come chime in!
Do you have the same projectors? I thought there would be two screws one for up/down and one for side to side but all I found was that one screw that makes it go side to side. The one on top right.
lexusAU
03-07-13 04:44 AM
