Rancid smell @high speeds
Old 05-12-15, 08:49 PM
Brands
Brands's Avatar
Default Rancid smell @high speeds
Hi there Cl. Whenever I'm in high rpm's my car cabin and engine smells like rotten eggs or something idk but it smells bad. It usually starts to smell when I hop on the freeway and I'm driving on the onramp to match the freeway speeds. Basically anytime I speed up fast sometimes slow. I would like to know if anyone can help me with this thanks for the help.
Old 05-12-15, 09:13 PM
Nixcision
Nixcision's Avatar
nothing to worry about, this is quite common with toyota vehicles. This is observed with their catalytic converters (which are supposed to help).
A good comparison is some of the people on the forum who have "cat-less" setups who get this "unburnt fuel smell" more common than those who only experience it at high rpm's once and a while
Old 05-13-15, 07:44 AM
ISPearl08
ISPearl08's Avatar
As he said above I suspect that to be your cats. Perhaps they're starting to go bad.
Old 05-13-15, 08:58 AM
Brands
Brands's Avatar
thanks guys ill check that out
Old 05-13-15, 10:30 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
try to get gas from another brand...
Old 05-13-15, 12:13 PM
Brands
Brands's Avatar
Fsho I'll try that out thanks
Old 05-13-15, 04:17 PM
Gville350
Gville350's Avatar
From Google : "There's sulfur in fuel additives; your engine isn't burning it completely and your catalytic converter is storing it and then releasing it as hydrogen sulfide when you add load to the engine and force more air through.
Try switching gas stations, or fuel grades; then try a thorough tune-up: replace the spark plugs, plug wires, fuel and air filters, and oxygen sensor, and clean the fuel injectors.
If that doesn't do it, replace your converter."
Old 05-13-15, 08:09 PM
Brands
Brands's Avatar
That sounds really great thanks I'll give it a try.
Old 05-14-15, 12:22 PM
Gville350
Gville350's Avatar
^FYI, I don't recommend wasting money on ANY fuel injector cleaners.
Old 05-14-15, 12:52 PM
daileycon
daileycon's Avatar
I work for the company that puts to precious metals into that cat so you best not be blaming it on that haha
Old 05-15-15, 08:53 AM
Brands
Brands's Avatar
yea lol i wasn't even thinking of that. mostly the gas and some other things
Old 05-15-15, 09:58 AM
Brands
Brands's Avatar
Old 05-15-15, 11:00 PM
hirsch2is
hirsch2is's Avatar
i use dot get this on my bmw really bad. i would run a induction cleaner through it and that would heat that cats up a little and burn everything out. i actually had a cat code for awhile and ran that and it never came back
joehpro
03-22-19 06:05 AM
2jznosht
Performance & Maintenance
08-12-12 06:04 PM
big-lo
05-16-06 10:55 AM
BlueSC400
Maintenance
01-25-02 11:43 PM
Quick Reply: Rancid smell @high speeds
