Differential Service
It makes sense that should be changed at least every 50k miles or so, I wonder why the service manual doesnt call for it, yet Lexus is recommending it. same with the tranny fluid.
It depends on what your definition of "Lifetime" is! I am planning on driving my car pass 200K miles (i have very long commute) so i changed my around 90k. To me, it was an easy and cheap preventive maintenance!
I can understand how the trans is meant to be a lifetime fluid because there's no darn fill/drain plug. However, on the diff, there is clearly a fill/drain plug. Go to Harbor Freight, get yourself the set of larger hex head sockets for the plugs. Then buy 6 feet of clear tubing at Lowes for installing the new fluid (gravity fed install); or get a pump-driven setup for quite a few more dollars. I used Lucas brand HD synthetic gear oil.
Wow! That is very cheap. Where did you get it done? Did they use Toyota Gear Oil. I would definitely have it done by the shop if it was this cheap (the Toyota fluid alone is over $30 a litter and you need to buy 2 for the job).
I would get it done at the dealer every year if it was that cheap!
Lexus of Sacramento
Invoice shows:
Rear Diff Service $30.45
Service rear diff per customer request. Service rear differential, W/o Limited Slip 2wd 06/13 T3
(2) part number 12157-10010 Gasket, Drain Plug $2.70
(1) part number 75904-14 75-90 GEAR OIL $11.90
1.4 QTS @8.50 EA.
Labor $30.45
Parts $14.60
Total $45.05
Invoice shows:
1.4 QTS @8.50 EA.
Labor $30.45
Parts $14.60
Total $45.05
Lexus of Sacramento
Invoice shows:
1.4 QTS @8.50 EA.
Labor $30.45
Parts $14.60
Total $45.05
Invoice shows:
1.4 QTS @8.50 EA.
Labor $30.45
Parts $14.60
Total $45.05
its supposed to be 75-85 synthetic. i always use the toyota brand but thats only because i get it cheap or free since i work there. otherwise its 30 bucks a quart but its good ****
definitely don't want to put conventional 75-90 in there. diffs are toyota/lexus weakest part IMO
MSRX
04-24-12 02:39 PM
